Like Tree9Likes
Old 08-01-2011, 03:46 PM
  #16186
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by nickypoo View Post
oops ya i ment the tekin 4 pole sensored. but i thought they were going to be a 550 can?
it really confuses me that the mmp can run say the 2400 1415 and some other 8th scale buggy ect. motors but it will struggle with smaller motors...
sorry btw its true im a noob. like it isnt obvious already tho
no, the tekin pro4 motor is a 540 can.
as ridley said, amps decrease as voltage increases, so the mmp is fine on 3 or 4 cells. it's 2 cell applications where some people have experienced the esc's shortcomings (myself included).
RC*PHREAK is offline
Old 08-01-2011, 03:59 PM
  #16187
Trader Rating: 127 (100%+)
So do you think the MMP will do fine with the Tenshock 4000kv on 3s? Just want to know as Im shopping for a system to run on 3s..
Neesh is offline
  #16188
nickypoo's Avatar
cool thank you!
btw east bound and down is effing hilarious!!!!
nickypoo is offline
Old 08-01-2011, 04:01 PM
  #16189
SaladFork's Avatar
As I mentioned the struggles with the MMP running other systems has to do with the firmware on the ESC. Some motors work fine while others seem to choke. I had this happen last week testing a new rotor, it would run on ESC 1, but not on ESC 2. It's a separate issue from the BEC problem. Some motors work, some work ok and some don't work at all.
And my RX8 and my Savox 1267 are not playing nice, so no ESC is immune from glitching issues.
SaladFork is offline
Old 08-01-2011, 04:06 PM
  #16190
10sctrel0v3r's Avatar
Originally Posted by SaladFork View Post
Ahh gotcha. I drilled another hole in between the two. It was close to the spur otherwise. Closer to the front tower it hits the rack underneath.
what battery tray are you using?
10sctrel0v3r is offline
Old 08-01-2011, 04:22 PM
  #16191
SaladFork's Avatar
The ERC battery tray, came with the conversion. I've always hated it because it's small and limited on what I can run.
Old 08-01-2011, 04:25 PM
  #16192
shadowracer24's Avatar
Originally Posted by Casper View Post
Try 5 up front. 7 was for a high bite track to calm the truck down. 7 will make the front end feel a little more lazy which is something I like. Guys that like a little more steering 5-5-3 for the diffs works to get you a little more steering.
Yea thats what I run is 5-5-3, tried the 7 in the center and front before and never liked it. Just saw where Ryan showed the difference in the losi and assoc. oil wgts and maybe thats it. I run assoc. 35wt both front and rear so that may be the problem, to heavy in the front.
shadowracer24 is offline
Old 08-01-2011, 04:41 PM
  #16193
ahh i see ill look around for a different tray
Old 08-01-2011, 05:02 PM
  #16194
8ight-e's Avatar
Trader Rating: 58 (100%+)
Something most people don't think of trying w/ the MMp (or ANY esc) that can help glitching is reducing the voltage on the internal BEC. Normally increasing voltage helps reduce amp draw, but because the servo gearing cannot be changed when you increase voltage, even to 6. you drive up the amp needs of that given servo. If you drop the voltage, it will actually draw less amps. Keep in mind it is at a loss of some torque and speed, but for many the extra speed does more harm than good anyway.
So for a tip; if you have some glitching trying dropping your ESC's BEC voltage w/ the castle software, you may find things fall into place. If that is not enough, you have to go w/ a direct run w/ 2s setups or a external BEC.
8ight-e is offline
Old 08-01-2011, 05:12 PM
  #16195
Jason Turner's Avatar
Trader Rating: 67 (100%+)
We are running this setup these days and it works really well.
http://www.losi.com/ProdInfo/Files/L...Lane-JBRL4.pdf
What are the "orange" springs on the back??
Jason Turner is offline
Old 08-01-2011, 05:25 PM
  #16196
larlev's Avatar
Castle has said same thing...staying at 5v or 5.5v is better than going to 6v. I have been at 6v for some time now with now issues. I really don't notice 5.5v servo speed vs. 6v...I would bet no one can.
The thing that has helped me more was setting steering travel so that servo wasn't over extending....makes a big difference in amp draw of servo. I also have cap installed w/ fan, transponder, temp sensor attached. Quite a few accessories plugged in and still no glitching...knock on wood
larlev is offline
Old 08-01-2011, 05:27 PM
  #16197
Trader Rating: 17 (100%+)
If you see on the sheet both springs are followed by a bracketed comment saying new springs. There are a new set of front and rear spring sets coming out for the SCTE.
mavrick0 is offline
Old 08-01-2011, 05:30 PM
  #16198
larlev's Avatar
You guys will love the truck even more when springs are out. I use 8ight springs for some time now and find it has greatly benefitted the truck and handling. You can always buy the 8ight adapters from Chris and use 8ight springs now.
larlev is offline
Old 08-01-2011, 06:08 PM
  #16199
Casper's Avatar
Trader Rating: 34 (100%+)
New Ten spring sets are in stock so your LHS or where ever you get parts from should have them or get them soon.
http://www.losi.com/Search/Default.a...m=ten%20spring
Casper is offline
Old 08-01-2011, 06:13 PM
  #16200
lbckevin's Avatar
Trader Rating: 96 (99%+)
Sweet...
Thanks Casper... I will have the hobby shop order them ...
lbckevin is offline
