Like Tree9Likes
Old 07-28-2011, 12:03 PM
  #15766
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by hacker07
I guess I'm not sure what to say at this point. It would seem that everything gets taken to a level with the multiple of 100. Casey is a good guy and doesnt offend easily. He also doesnt take crap. You specifically pointed out that you will take his word wtih a grain of salt given he made some good points and was just trying to help those out that he could.
You all just dont get it. I get yelled at almost weekly about how much info I give out in here. But, seeing as I just keep getting walked on as I am biased according to all...maybe its not worth it to get yelled at anymore. You all have a nice afternoon.
If you want the BCE chassis, it looks nice, go for it. If you want the TLR chassis, go for it. If you want to make your own, I'm ok with that too. But seeing as your first thought is to say it isnt good because the people have not spoken, thats a bit short sighted to me.
Hey man, listen, I and many many others are tremendously grateful to you for this truck's existence, the development of it, the resolution of the minor issues, the info you put out, the ongoing support, release dates, spring kits, etc..
You and casper being here played a huge part in having me, and again many others, jump on board the losi ship, where I shall remain. Remember that. You are doing a fantastic friggin job, and we appreciate you. It's the internet, don't let shit get to ya.
lowroad is offline
Old 07-28-2011, 12:06 PM
  #15767
BmainStar's Avatar
Originally Posted by Feint Motion
Hopefully next week. Reserved 2 at Pegasus.
Ah Kool welcome back !! Pegasucks? LOL some one has that on thier sig, Too funny think it was UMM-Winning. Any way after posting that I had never even had my front end apart I tore every thing down and all was perfect the bearings look and roll as new!!Put the lt. Outdrives on and the alum pin holders and checked my chassis on an granite surface plate all is well!! Just don't want to get it dirty Uggh..LOL Wish I only raced indoors! Good luck with this one Bro! And there is a one day race event on sat up in the Victorville area Panther tires Coyote hobbies summer jam or slam I dunno? If you want to pony up 30 bucks for a shirt,a set OF Panther tires and the chance to get lapped by one of the fastest SCTE drivers I have ever seen, Panther driver Brian Sullivan,Go Up!!
BmainStar is offline
Old 07-28-2011, 12:21 PM
  #15768
khannibal's Avatar
I 2nd this... I have the truck BO'd on AMain and got alot of info from this forum! Kudos to Casper/ hacker07, salad and the rest of you guys. This thread rocks. Keep up the great work.
khannibal is offline
Old 07-28-2011, 12:23 PM
  #15769
hi guys..
i just installed the HD outdrives, but i noted the outdrive on one side(both center/rear) there is some 'play', meaning i can push/pull abt 1mm or so. while the other side on the cap is nice n tight. i tried switching sides and putting xtra shims but dat doesn't seems to help?
any one has the same issues?
thanx
chiatw73 is offline
Old 07-28-2011, 12:24 PM
  #15770
racerx1920's Avatar
Trader Rating: 218 (100%+)
i agree
racerx1920 is offline
Old 07-28-2011, 12:35 PM
  #15771
Can someone post a pic of the bottom of a BCE chassis that has some track time on it? Just curious how they are wearing. Thanks
Mototech is offline
Old 07-28-2011, 01:28 PM
  #15772
Originally Posted by chiatw73
hi guys..
thanx
I think what you may be feeling actually has to do with the metal inserts that go into the plastic diff case. See, when most of us put a diff together, we put the sun gear in the larger portion, then we cram the pins with blocks and spider gears in and then oil and then the last sun gear and screw the diff together. This pushes everything to one side and then when you go to move the outdrive, what you are actually moving is that metal insert and only one side moves because those metal blocks that the diff pins ride in hold the spider gears all to the one side. I have started when I get a new diff case, to glue those metal inserts in and this has served to keep things free and operating properly. I tried getting them to bond the two but they cant.
hacker07 is offline
Old 07-28-2011, 01:50 PM
  #15773
stompy's Avatar
Thought I would share this. AE shock boots, perfect fit and made of a much stronger material.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-new-image.jpg
stompy is offline
Old 07-28-2011, 02:43 PM
  #15774
dtr
dtr's Avatar
I think what you may be feeling actually has to do with the metal inserts that go into the plastic diff case. ... I have started when I get a new diff case, to glue those metal inserts in and this has served to keep things free and operating properly. I tried getting them to bond the two but they cant.
What about putting thread on the case and the insert? This would require changing the hex for something else, of course.
dtr is offline
Old 07-28-2011, 02:47 PM
  #15775
larlev's Avatar
What are the different holes on the Losi alum servo arm again? Outside hole gives faster steering, and inside is slower...is that correct?
larlev is offline
Old 07-28-2011, 02:53 PM
  #15776
Trader Rating: 20 (100%+)
when will the new springs be out
xxxtruck is offline
Old 07-28-2011, 03:46 PM
  #15777
We have found the inside to be better on this truck in general. The outside one makes it react very quick off center.
The rear springs got through QA but were waiting on a location in the warehouse and then will ship. Hoping tomorrow or monday.
hacker07 is offline
Old 07-28-2011, 04:21 PM
  #15778
annonymous's Avatar
Trader Rating: 21 (100%+)
Default Diff Case Assembly?
would also like to hear from someone about this
annonymous is offline
Old 07-28-2011, 04:24 PM
  #15779
umm winning's Avatar
probably going to sell my losi on FEE-bay soon
umm winning is offline
Old 07-28-2011, 04:35 PM
  #15780
Outtacontrol58's Avatar
Trader Rating: 92 (98%+)
Thumbs up
You will be Ummm Losing if you do lol. Here is a pic of my truck, just got painted by Larry from RCKustom Graphics
Outtacontrol58 is offline
