Like Tree9Likes
Old 07-21-2011, 11:30 PM
  #15136
BmainStar's Avatar
Originally Posted by Ridley View Post
We've bent a few testing them out, but they were all the result of some pretty knarly crashes or hard landings coming up short on big jumps. They just don't bend unless there's a crash or crazy hard landing involved. We've found the failure rate to be about the same as the stock pins, just lighter.
However, hingepins should be something you check everytime you have your shocks off. If the arms don't flop around and fall 100% freely, there's an issue. Hingepins should be removed and dry lubed, and the pivot holes on the arms should be cleaned out and dry lubed as well. The pin should fall freely through the arm, or just about fall through the arm under it's own weight when fitted and lubed properly. Slop is always better than bind. A free and loose suspension system is probably the number one key to a great handling truck.
Hey Rid,what type of dry lube do you recommend? Thanx!
BmainStar is offline
Old 07-22-2011, 12:11 AM
  #15137
Buzz3's Avatar
Really? Nahhh, too easy.
Buzz3 is offline
Old 07-22-2011, 01:01 AM
  #15138
BmainStar's Avatar
Dry..lube!! lol maybe you shoot Blanks??
Old 07-22-2011, 01:46 AM
  #15139
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
i saw this one coming
on a more serious note, does anyone know if lunsford make the captured balls for this scte? for example, the ones from the steering links, toe links front and back? if so please post part #"s.
Mr.juarez is offline
Old 07-22-2011, 02:37 AM
  #15140
SaladFork's Avatar
Not sure about Lunsford but Dubro makes some, they are bullet proof. I bought a bag of 24 and have swapped out as needed, sorry bro no part number.
SaladFork is offline
Old 07-22-2011, 04:31 AM
  #15141
8ight-e's Avatar
Trader Rating: 58 (100%+)
I do just fine keeping them clean no lube etc.. but I'll admit I have spent a little less time maintaining my scte than my other trucks.. so far it's been a set it and forget it type vehicle to some extent. I don't wreck much (at least prior to the pin issue and the endo's) and tyipcally run 1,2 (even w/ the issue) but I'll give you I've had some hard landings.. as I noted 'two triples' and one is a platform triple and the other is just a large 1/8 scale triple that you bearly make on a tight line. On the comparison vs stock pins.. I've bent two titanium, zero stockers in 6 mos. so my math comes out a little different and will be sticking w/ stock for now. I'm just glad I figured out what was wrong, it was frustrating endo'ing off even easy jumps at times... let alone the big ones, not to mention brutal to my body and bumpers.
8ight-e is offline
Old 07-22-2011, 04:37 AM
  #15142
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
Originally Posted by bhdien View Post
Hey guys,
I am having an issue with my truck. I overheated it once and let it rest for the rest of the day, the next day i go to run it, the wires on the motor gets so hot that the soldering came off of it and the motor wires came undone.
I am running a Mamba max pro with a tekin sc 5.5 on 5500mah 60c with a 14tpinion on stock spur.
Would any of you know what could be causing this problem? It's been running fine days before but i just have no idea whats going on now. Could the esc or motor gone bad? Any help would greatly be appreciated.
Thanks!
Well could be a couple things..one your soldering skills are might not be the best, a poor solder can cause an esc or motor to run over 20 degrees warmer. Also can cause the solder joints to melt off. Next you may have a bad bearing somewhere, this will cause the truck to work a lot harder to get going. Pull the motor out and roll your truck on the ground it should roll nice and smooth. Next it could be you lipo has too low a C rating causing heat to build up.
Those are my queses.
SCTRacerX is offline
Old 07-22-2011, 04:40 AM
  #15143
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by 10sctrel0v3r View Post
it says the exact same thing under ride height also so i guess he has it set with no camber?
Ride height is the height of the chassis, off the ground. I just looked at Losi.com and saw the following for each:
Truhe has -1 front and rear camber (tilt inward), and 28mm front height and 31mm rear ride height.
Dunford has -0.5 front camber and -1.5 rear camber, and 30mm front ride height and 28mm rear ride height.
If you're seeing something different, then try to re-download the setups or update Adobe Reader. If this is what you're actually seeing, then you might be misunderstanding what the settings are/mean..
goehm is offline
Old 07-22-2011, 04:45 AM
  #15144
8ight-e's Avatar
I like the same as Truhe, -1 f/r cambers, bout 3' out on front toe, 28mm front 29-30mm rear, I run full droop in the front ~89mm and 101mm rear as well.
8ight-e is offline
Old 07-22-2011, 05:56 AM
  #15145
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Set it to -1.
ChrisAttebery is offline
Old 07-22-2011, 06:09 AM
  #15146
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
No, he is correct. One of the setup sheets are wrong. I don't remember which one but I pointed it out about 800 pages ago and it never did get corrected.
alvinsmith75 is offline
Old 07-22-2011, 06:14 AM
  #15147
10sctrel0v3r's Avatar
thank you guys, ill set it to -1 as for the toe, how do you all calculate this if you have no tools for checking it?
10sctrel0v3r is offline
Old 07-22-2011, 06:23 AM
  #15148
Originally Posted by SCTRacerX View Post
What are the best TBR bumpers for the SCTE? The ten-t or the SCTE ones?
TBR SCTE in the front and TBR 10t in the rear
LRPO is offline
Old 07-22-2011, 08:23 AM
  #15149
We have all mostly gone to what I will refer to as the Aaron Lane setup. Sometimes we change out oil and all but the ride height is 27mm before body front and rear. This is not on bumpy tracks though, we raise it up for those.
hacker07 is offline
Old 07-22-2011, 08:36 AM
  #15150
I just went through my truck and used the Cactus Classic setup. It looked too stiff in the rear to my eyes. Glad I saw this. I'll drop the rear end down a few mm.
BTW: What is the pitch of the thread on the shocks?
