DECISION WHICH TO BUY!?!?!?
#16
#17
Well I think I have decided on the Ofna Jammin SCRT-10. I'm ordering the RTR kit, but I'm also purchasing the Novak 4.5T 550 Ballistic brushless motor and Havoc Pro SC ESC. From the research that I've done, that's about the best setup to get. I'll be using the stock 2.4ghz radio that comes with it. The servo will also be stock. I hope to eventually get the Airtronics TX/RX and HiTec servos, but for now the stock will have to do.
What do you guys think about tires while I'm at it? I'm hearing good things about JConcepts Goosebumps and Bowties....
#19
#20
at the track i run seems like more people run 2wd with a slash class and a sc 17.5t. The 4wd class are more experienced guys and its an open class so motor choice is open so guys are running some pretty fast stuff, so an rtr 4wd wouldnt compete. But thats where i run probably different at other places.
Now if your going to be bashing more then racing go with the slash 4x4.
#21
kit ... picked, you said you got the jammin ...
good truck but now if you plan on racing you need to go to the track and find out what tires are others using ... also don't go crazy and upgrade everything right off the bat ... look into a good servo and radio and shocks ... tune those first along with the esc and track time .... then look into other upgrades ...
again thats only my 2 cents
#22
