Battery Moisture?
My brother has a traxxas bandit and drove it outside when it was really humid, now there is moisture inside the battery, is that bad or normal?
Well, if it was humid out, then moisture probably did get in there. I would let the pack sit so it can completely dry out before running it.
Can also take a hair dryer to it to speed up the drying pricess...low heat.
Originally Posted by rangerjkb
(Post 8491503)
Look at you in your old age.... full of wisdom. |
Either way you/he should be fine. I've seen nimh packs run under water...
