New Ballistic 540 Replacement Items
Company Representative
Novak Ballistic Epoxy Dipped Hand Wound Stators
Novak’s Ballistic 540 Hand-Wound Stators have revolutionized the R/C motor market since their debut over a year ago. A Novak motor’s turn can be changed with the simple switch of a stator; cost effective and convenient! Novak continues to transform the brushless motor market by introducing the all new Ballistic 540 Epoxy Dipped Hand Wound Stators – 6.5T – 25.5T (#S6606E - #S6625E). These new stators include all of the features of Novak’s hand wound stators with the added benefits of epoxy. Each of the eight stators offer strengthened reliability and higher power operation performance of the motor— ideal for extreme racing conditions.
EPOXY COATING
The Ballistic Hand Wound Stators are dipped in a special motor winding epoxy and then oven-cured for several hours. Once the epoxy is cured, it prevents the wires in the stator from moving or rubbing against the laminations and other wires in extreme racing conditions. Preventing this unwanted contact avoids shorts in the motor coils, which can lead to premature failure. The epoxy also helps transfer heat from the wires to the lamination, helping motor operation at higher power levels. All around, the epoxy coating improves the reliability of Novak’s already high-quality stators and provides extreme vibration resistance.
Ballistic 540 Epoxy Wound Stators
1S Graded, Sintered 12.3mm Rotor
This replacement rotor is especially suited for use with 1S Input Voltage. The 1S Graded Sintered Rotor - 12.3mm (#S5953) is an affordable rotor rated under 1200 according to popular magnetic strength meters, such as Zubak's Speed Meter 2™.
These rotors are selected and graded for maximum RPM in 1S LiPo applications. With the magnet at a lower pull, the rotor allows a higher RPM, increasing the Kv of the motor by approximately X%. Novak prides itself on the quality and consistency of our rotors. All rotors are magnetized in house, and are tested to ensure even and balanced magnetization.
The 1S Graded Sintered Rotor is compatible with all of Novak’s 540-sized brushless motors, including the Ballistic, Velociti and SS Pro series' of motors.
Features:
....High-strength sintered, Neodymium magnet for maximum motor acceleration, braking power and performance in high temperature conditions
....Nickel-plated for stronger surface and resistance to corrosion
....Meets ROAR & IFMAR specifications
....Novak designed
EPOXY COATING
Features:
....Novak designed
Will new Ballistic motors include the new Epoxy Dipped Hand Wound Stators or will this only be an optional stator to buy seperately?
Keep up the great work, I am running 3 Ballistics in my cars/crawler and they are awesome motors!! I am running a Ballistic 13.5 on 1S in my 12R5.1 and it works great but I am running on a small track and not pushing too hard so it doesn't produce much heat (usually around 100-110 degrees after 6-10 mins of constant runnning). Would I see any improvement with the 1S rotor or is it more suited to applications that are really stressing the motor with a lot of heat or over-gearing?
Our low gauss 12.3mm rotor is geared for Oval single cell racing:
These rotors are selected and graded for maximum RPM in 1S LiPo applications. With the magnet at a lower pull, the rotor allows a higher RPM. Novak prides itself on the quality and consistency of our rotors. All rotors are magnetized in house, and are tested to ensure even and balanced magnetization.
Super Moderator
Trader Rating: 31 (100%+)
Super Moderator
I know what guass is but most people don't so I didn't want to get into that whole thing..
This is a tuning rotor graded for low voltage operation---primarily in oval events.
I think the epoxy dipped stators should become mandatory for
every motor you produce.
There's too many ingenious racers out there that can remove a couple
winds and solder it back together.
I understand your marketing of making a stronger , more reliable stator for racing but the real reason is to keep motors from being tampered with.
Does Novak have a minimum Inductance number for it's motors ?
We are investigating offering epoxied stators for all of our motors, but this measure is being taken primarily to mitigate burnt stators in spec (high-wind) motors. Re-winding motors to cheat was a secondary consideration. Oval racers (using timing/boost escs) are particularly hard on motors---pushing these motors beyond their design specs.
We do not use inductance in our motor manufacturing; we measure the stator resistance of every motor to verify the winding; each wind has a resistance range that indicates that the stator is correctly wound.
x% huh? thats a great figure!
I was just going to say, X%, where X is equal to.....?
If I were to use Novak's trade-in program for new motors would the new motors have the epoxy coating? My 5-year old velociti's finally are starting to go out one by one. So I might as well swap the whole arsenal. I wish the trade-in could do could do 10 items. I have 6 motors and 3 GTB's. Well, actually I sent the GTB's off last week for the new GTB 2's. I hope they rock like the original GTB's have been for the past several years.
thanx
chris
thanx
chris
The motors in our Trade-In programs do not include the new epoxied stators; they are only offered as replacements, for now. We will be offering Factory Team motors soon with the new stators; these new versions will replace these motors.
Adding the FT motors to our replacement/exchange programs should be do-able in the future. You can return as many items for exchange (at one time) as you wish---you many need to fill out additional return forms. But shipping both ways is much cheaper, per item, when more products are sent at one time.
thanx
chris
thanx
chris
