Charge more than one battery?
Can this charger charge more than one battery at a time? The X-10 one. http://www.neumotors.com/Site/Chargers.html
it looks like it can
Nowhere does it say it can, it looks single kreskin.
This one can and does charge two at a time......
http://www.amainhobbies.com/product_...er-6S-15A-300W
This one will charge four at a time.....but at a much lower wattage.....
http://www.amainhobbies.com/product_...rger-6S-6A-50W
^^^ Exactly, but its limited by the 10amps max charge rate. To charge lipos in parallel at above 1C charge rates, you need 20amps max charge rate from a charger.
This one looks like Neu had iCharger make one for them, so it might already be an iCharger, just rebadged. Look at the 206b or 208b with 20amps max charge rate and either 300 or 350watts of charger output power.
If you want two separate charger outputs, you need to look for a dual type charger.
