Tire mounting ????
Here is what I do/use and I never had a tire come off the wheel.
Put the insert in the tire then put the tire on the wheel, push the bead of the tire in to the bead then I put my jcon tire bands over the tire where the band is flush with the side wall.
I use loctight glue with the blue cap you can get it from lowes, I run a bead of glue on the out side off the tire the glue will slide on the bead and let that tire sit tell it's dry.
Hope this helps.
Ty
Hope this helps.
Ty
