MBX6 ECO Thread
Old 01-26-2017, 06:04 AM
  #7531
For what it is worth I solved the problem. I went from using a plastic Serpent gauge to measure the camber to a Hudy Set-up station. Hence the camber results were different. It also appears that I can increase front and rear camber more as the tires are not wearing in the center. Wear is in between the center and the front sidewall. I also took out the bottom washers on the arm (not sure if removing the washer did anything). FYI the shock tubing was a waste and did not last. The car is good now and competitive.
SouthFloridaApp is offline
Old 01-26-2017, 12:16 PM
  #7532
Originally Posted by Nsaneo View Post
I've come up with a real good set up for our tight indoor track. It has a spine jump into a tight hairpin onto a tabletop into quad to a hairpin into whoops hairpin into to medium triples then long sweeper to a long straight. Tight flowing track.
Diffs 5/7/2
Shocks front 450 rear 27.5 wt front
Spring stock
Medium droop
Ride height 27/30
Move rear upper link to the top on tower
Steering Ackerman all the way back rear holes
Camber -2
Front Upper arm up to top
front Upper pin position middle hole
Front Upper pin bottom hole
Shorten wheelbase
Rear shocks inner hole on bottom middle on top
This car turns awesome both on and off power!
Tekin rx8 at 70%
Tekin 2650 t8 motor
A lot of guys going to 4 pole 4000kw for torq or 2350 truggy motor
Hope this helps you as it made a huge difference for me. Started with 16sec laps now I'm down to low 14 with a few 13.6s
Do you have this on a setup sheet. Some is unclear. Like what rear springs and front shock mount locations. And the front upper arm and pin details I'm little unsure of.
Mugenmulisha is offline
Old 01-26-2017, 12:48 PM
  #7533
Diffs 5/7/2
Spring stock
Medium droop
Ride height 27/30
Camber -2
Shorten wheelbase
Tekin rx8 at 70%
Tekin 2650 t8 motor
Is this setup on a sheet anywhere. I'd love a copy. Some details are unclear.
Old 06-20-2017, 08:19 PM
  #7534
PorTX's Avatar
What is the going price on rollers? Every one I have seen listed says SOLD....
PorTX is offline
