MBX6 ECO Thread
#5671
Anyone have a shock cap I could pick up? Shoot me a pm if so. Thanks guys.
#5672
#5674
I use the hitec HS-7955TG High Torque Titanium Gear Coreless Servo
#5675
My hitec bit the dust the other day...gears stripped but their customer service is AWESOME. Is out of warranty but they are going to help me out.
#5676
Is there some info on the little suspension spacers on the eco. What they do, for etc.
#5677
R/C Tech Elite Member
For information on what this does to the handling of the car, there are several guides out there that are really good; JQ, The Guide, Hudy setup guide and I believe ther is a XXX Main one as well - google is your friend here.
#5679
They are used to shorten or lengthen your wheelbase. The base setup tells you the number of spacers to use for that setup and you can add or remove as you need.
#5680
I will post pics after I comlete the mbx7 eco build.
#5681
Yes, I will be converting a mbx7 to an eco. I've converted several mbx6 nitros to electric using the eco stock battery tray, servo mount/receiver box and motor mount. I've made a chassis drill template based on the holes in the eco chassis. Using a drill press I drill and countersink the required holes. The only difference is the chassis length and one of the battery tray holes can't be drill due to the extra slotted hole in the nitro chassis.
#5683
I converted 2, for my brother, which he let me test and they feel very similar to the stock eco. The chassis length makes a difference. I prefer the shorter chassis. The latest one I converted had a BCE chassis and I like it better than my stock indoor eco. It feels extremely light on the track and weighs in at 6.5 lbs without a battery. I've read several times in this thread that the BCE chassis is a must and couldn't see how they could make that much of a difference until I tried one.
#5685
I managed to make the A-main at the CRCRC midwest champs with the eco. The car was great all week. I didnt stray to much setup wise. I wish i could have made a few more setup changes to see how it worked out. But he car is so reliable and smooth.It was a great week.
