Jammin CRT.5 Brushless
#377
Yellows got to go. I was wondering if the Traxxas Bandit tires would fit the CRT. 5. Would the Front or Rears Bandit stock wheels/Tires fit? Or they both fit? They look 2.2 I just don't want any surprises.
Gonna get that wing in black too.
#378
Just buy the best replacement Parts as they break til it's rock solid.
So guys does anyone run 16 tooth pinions? This thing is too slow on 3s 14/46. What temps you guys getting??
#379
What are you using for a motor?
#380
I put my Rustler front rims on mine and they fit fine. My car isn't built yet, I just wanted to see how the tires looked.
#381
I have rustler rear wheels on mine. I have the extended RCM chassis, but it should fit on all chassis's. Short Course wheels/tires also work very well
#383
Novak HV 7.5 Turn, 3000kv, with Mamba Max Pro ESC. i have the stock tune on the ESC. the 14t is just way too slow, even for my wife. i'll pick up a 16t and hope it gets the speed we're after. the motor temp is less than 100 degree's. so obviously it is not geared right. i have a 19t but i'm thinking that is a little much lol. i'm tryin to get this truck all ready for my wife to bash on this summer. it has to be fast, but no temp issue's. she likes to drive them not work on them hahaha!
#384
#385
Finally some pics of my Beast. No body pics yet because i'm using a beater body from an old t3. I will have some new pics up with a body as soon as I paint the new body i have for it. Just waiting for the temps to get a little warmer outside.
RCM (XL) Chassis
Mamba Max ESC
HK 3660 4000kv
Rustler Rear Wheels all around
Some Aluminum Bits
Dont mind the grass/dust, didnt have a chance to clean it after the last bashing session
RCM (XL) Chassis
Mamba Max ESC
HK 3660 4000kv
Some Aluminum Bits
#386
#387
Hey guys,
Been reading through the thread pages and everyones crt looks good. I just picked one up and should be arriving soon. I just can't make a final decision on a motor/esc combo. Ive been looking at the CC sidewinder sct combo, CC MMP SCT combo, and a 1/10 hobbywing combo. I would like to gear this truck for about 50mph and run on 3s, It will be more of a pavement surfer. I would also like to run 1/8 scale on road tires on the truck. Also wanted to keep this easy on the wallet, so the sidewinder combo looks good but will I be asking to much from it?
#388
Hey guys,
#389
Guys, I suggest we give out more details on what we're running. Generic motor names w/o kV or voltage makes it hard to do comparison.
How about giving motor kV and voltage? Then we can do apples to apples comparison to pick the right pinion. Also, the tire diameter is important. Some are running stock rims, some have 2.2 truck, and some have even bigger.
And, can anyone confirm that internal ratio is 3.25?
#390
i have the Novak HV 7.5 and Mamba Max Pro ESC. I use Turnigy 3S 25C 5,000mah batteries. Current gearing is 14/46. but i am going to a larger pinion soon...most likely a 16t. Currently using stock wheels/tires but I would like to run 1/8 buggy wheels/tires.
Novak HV Brushless Motor Specs
Number of Turns: 7.5
KV (unloaded): 3,000
Design: Sensor-based
Magnet: One-piece, multi-pole neodymium
Watts: 620
Motor Size: 2.84”; 72.1 mm (Length); 1.41”; 35.8 mm (Diameter)
Shaft Diameter: 5 mm
Motor Weight: 8.36 oz. (295 grams)
-http://www.teamnovak.com/products/brushless/hv_motors_5mm/index.html
