Old 08-02-2004, 11:07 PM   #1
Striker's Avatar
Default How do I put a SG engine on a rc10GT?
Just like the subject line.... I know that the RTR has one, but it's not the same diamiter as others. If posible, I would like to use NTC3 parts.
Striker is offline   Reply With Quote
Old 08-04-2004, 01:00 PM   #2
Default sg in a gt
i bought a new gt and had 5 sg motors that i would have loved to use in the truck. i found out the hard way that the ntc3 parts do not work because the clutch bell is wider than the gt and the gears won't line up. the losi parts do not work. in fact i don't think anything will work. even if you could get a bell to fit on the sg. i had alot of knowledable people look at my truck before i gave up. save yourself alot of headache and get a threaded shaft motor.
sedanaddict is offline   Reply With Quote
Old 08-05-2004, 10:05 PM   #3
Striker's Avatar
I thought I read in one of the mags, that one of the pros were using a 3-shoe clutch off of a NTC3. That's why I thought that someone had pulled it off.
Old 08-05-2004, 10:32 PM   #4
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I know of one AE driver that has put the NTC3 clutch on a GT, but it required a specially made clutch bell. I don't know of anyone that has done it, with available OTC parts.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-05-2004, 11:35 PM   #5
Striker's Avatar
Figures. I don't have anything against the stock set up, I just wanted to be able to use SG shafted engines I have here at the house.
Old 08-06-2004, 11:03 AM   #6
Trader Rating: 37 (100%+)
it can be done. there are lots of guys here that run ovals in parking lots that have sg shaft .12 or .15 small block engines in there gts. i think you have to use tmaxx parts, like the clutch bell, flywheel, etc. and raise the engine with the rtr mount. pm me if you are serious and i'll ask my friend what parts are needed.
Buggy Master is offline   Reply With Quote
Old 08-06-2004, 02:39 PM   #7
I run Gt`s on dirt ovals and to run a sg crank motor I use XXXnt motor mounts to pull the motor back. YOu just have to cut slotted motor holes instead of the gt style.
saints1115 is offline   Reply With Quote
rc10gt and a (p) shaft engine conatus Nitro Off-Road 1 04-15-2008 07:46 AM
Engine for my FT RC10GT, and T-Maxx ProMaxx316 Nitro Off-Road 1 02-06-2008 06:38 PM
rc10gt engine mounting Q NiTeHaWk4787 Electric Off-Road 7 08-10-2006 08:15 PM
best engine 4 rc10gt hogdaddy77 Electric Off-Road 20 07-28-2004 01:30 PM
Best RC10GT P/S engine? NWDave Electric Off-Road 6 04-21-2004 08:56 PM
