problem with novak 4.5 and lrp SXX new version? help
Everytime i drove my jammin scrt-10 with my novak ballistic 4.5 and my LRP SXX new version it stadder at start then it run. I had the same problem with my new mamba max pro then i replace it with the LRP and problem fix. Now the issue came back. I replace the receiver, i took out the amd transponder and replace it, change battery also i used lipo 2s 5000mah 40C, has everyone run into this same problem and know how to fix it?
thank you for your time.
Please check/replace the Sensor wire, as it can cause those types of symptoms.
i have try that but i will try it with a new one to see what happen
