Old 07-27-2004, 05:28 PM   #1
GReddy's Avatar
Send a message via AIM to GReddy
Default engine faillure
engine wont start!!???
any suggestions?
GReddy is offline   Reply With Quote
Old 07-27-2004, 05:51 PM   #2
PTP Racing's Avatar
you've gotta give more info than that
check glow plug first
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 07-27-2004, 06:32 PM   #3
GReddy's Avatar
i tried that i even tried using a brand new one
the engine is a brand new GX-21 w/ pull starter
i tried priming it
putting some fuel in the carb
glow igniter is charged
i have a reliable power source
theres fuel in the line
i tried loosening the glow plug
it wont start
im not sure if i flooded the engine or not but i removed the glow plug and turned the car upsidedown but no fuel came out
Old 07-27-2004, 06:55 PM   #4
GReddy's Avatar
ttt
Old 07-27-2004, 08:37 PM   #5
GReddy's Avatar
i tried priming it
it wont start
the engine wont start!!????
Old 07-27-2004, 10:03 PM   #6
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
is it even trying to turn over or is it not doing anything?
does the flywheel move when you pull the cord? could be the one way bearing in the pullstart slipping or not installed.
are their any blockages in the fuel line or exaust system?
take plug out and attach you glow ignighter to make its not defective. glow ignighter could be defective.
check lines for air leaks. check to see if fuel lines are routed correctly.
you may want to remove your engine and dissasembe and reassemble it they are simple to do and then you know it's right.
you may want to check the clutch also.
tough question. good luck.
cmain is offline   Reply With Quote
Old 07-27-2004, 10:09 PM   #7
GReddy's Avatar
ic but i just got it 1 day ago and this is my first time trying to start it
when i pull the cord nothing happens but i hear a psst sound coming out
the only problems ic on ur list is one way bearing
clutch
or the engine
like i said i just got it 1 day ago
waaaa!!!!
Old 07-27-2004, 10:46 PM   #8
compaq888's Avatar
Send a message via AIM to compaq888
check to see if the main needle is tighened all the way. It happened to me once, fuel in line, pullstart was working, flywheel moving, fresh glow plug, charged glow plug ignitor but it didn't start. Then i found out that the main needle was closed all the way, so I screwed it out to standard setting and the engine started on the first pull.
compaq888 is offline   Reply With Quote
Old 07-27-2004, 11:06 PM   #9
GReddy's Avatar
wen i pulled the pull starter the fly wheel turns for bout 1 inch of chord then i hear a metaly cling sound
is this normal?
Old 07-27-2004, 11:20 PM   #10
GReddy's Avatar
wen i pulled the pull starter the fly wheel turns for bout 1 inch of chord then i hear a metaly cling sound while 5 more inch of chord just flys out
is this normal?
Old 07-28-2004, 01:50 AM   #11
Aaron Waldron's Avatar
Make sure the carb is working correctly. Take the air filter off and make sure that the throttle needle isn't closed off (use the idle screw to adjust that). Reset the needles to the recommended factory settings, and make sure the high and low speed needles are tight.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-28-2004, 09:55 AM   #12
GReddy's Avatar
wut do u mean closed off?
lik the needle is in the this thing making a line straight through?
if it is at neutral its closed off
but there is a little crack for the whole thing wen in neutral
Old 07-28-2004, 12:14 PM   #13
15
prime it more then u usually would, almost to the point of flooding it, then try to start it
15 is offline   Reply With Quote
Old 07-28-2004, 12:57 PM   #14
GReddy - That sounds right from your description..but I'd turn the idle up more to help you start it.
Don't prime the engine to the point of almost flooding it. You'll more than likely foul the plug and hydro-lock the engine. Two-stroke engines start easier when they're a little on the lean side than anything.
www.liverc.com
Old 07-28-2004, 04:51 PM   #15
GReddy's Avatar
YES!! it works i went to RC tech and they said the high speed needle was open way to much or somethin so yea
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
