Old 07-27-2004, 04:55 PM   #1
TSB
Default XXX BK2 set ups
Has anyone found a killer set up for the Bk2?
TSB is offline   Reply With Quote
Old 07-27-2004, 05:23 PM   #2
want a copy of mine someone said it was real fast j/k see ya in Canby baaaaaaatttttllllle
brian6989 is offline   Reply With Quote
Old 07-27-2004, 07:44 PM   #3
Aaron Waldron's Avatar
On what kind of track are you planning on running?
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-29-2004, 07:10 PM   #4
lem2's Avatar
Default Ti turnbuckles
on my BK2 have beenbent, and its not even on the side where the collision happened
Any body experiencing Losi's Ti turnbuckles bending?
lem2 is offline   Reply With Quote
Old 07-29-2004, 10:00 PM   #5
Gutter Ball's Avatar
Yah, a lot of turnbuckles are bent on my 2 BK2's. I can understand in my offroad buggy, a couple of rough tumbles and collisions.....but they're bending on my stock oval buggy too. I actually broke one on my stock oval BK2. I didn't even hit anything, I rolled her and broke one of the rear buckles!
The ones on my both MFE's are fine though
Gutter Ball is offline   Reply With Quote
Old 07-30-2004, 10:17 AM   #6
nutfluff's Avatar
Send a message via AIM to nutfluff
Default Re: Ti turnbuckles
I've had it happen on the rear of mine. After further research I found out that even though they are made by Lunsford, Losi wanted them to certain specs that aren't as rigid as Lunsford's. Therefore, if you were to return them to Lunsford they would not guarantee them and tell you to go through Losi. Just replace them with actual Lunsfords and all should be fine. This is one of a few faults with an otherwise exceptional buggy. I switched from a B4 and in my first race night bettered my overall race time by 15 secs!!!!
nutfluff is offline   Reply With Quote
Old 07-30-2004, 10:29 AM   #7
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
My fast friends tell me that the BK worlds setup is great, but they changed the rear spring form a red to a yellow.
mafiaracers is offline   Reply With Quote
Old 08-04-2004, 06:18 AM   #8
fastolfart's Avatar
I have bent mine as well, I found that X ray have excellent camber links and are using them now, cant beat spring steel
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
