TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 10-14-2011, 06:31 PM
  #10591
Default Curious
Should I get the tungsten carbide balls for the diff or just plain carbide and be happy. Any significant difference in the two?
Thescoobyrs is offline
Old 10-14-2011, 08:01 PM
  #10592
mjk1210's Avatar
ceramic
mjk1210 is offline
Old 10-14-2011, 08:27 PM
  #10593
Trader Rating: 43 (100%+)
Default Clear over head pic
Can some one direct me or post a clear zoomable over head shot of the 22 with a tekin system or like one and transsponder mounted. Nitro guy going electric for the winter and these miniature cars have em stumped on where to run the wires and mount all the stuff and still have the body fit.
crazysavage is offline
Old 10-14-2011, 08:31 PM
  #10594
Muggydude's Avatar
Trader Rating: 92 (100%+)
You need to get creative, A great place to mount the transponder is over the servo with some velcro. Shorten up your wires if you're having real problems.
Muggydude is offline
Old 10-14-2011, 08:32 PM
  #10595
Muggydude's Avatar
Ok, so I haven't really payed attention to 1/10 for the past 6 months- wat did I miss?
Anything new about the 22? Upgrades?
Old 10-14-2011, 08:33 PM
  #10596
CAMPBELL20's Avatar
mount the transponder on top od the servo and the tekin on the battery tray right in front of the shock tower and reciever on the chassis in between the battery mount and the servo
CAMPBELL20 is offline
Old 10-14-2011, 09:11 PM
  #10597
Default Lol
Originally Posted by mjk1210 View Post
ceramic
This is the diff I'm talking about here... Ceramic is to hard and will cause the diff to slip buddies of mine explained this to me already and it will have to stay pristine clean for the balls not to tear up the ring, just saying.. ? Not sure that's a good idea but great if it was a bearing.. Wish it would work but not going to happen
Old 10-14-2011, 09:14 PM
  #10598
Ok,
I went 2mm inside rear camber link and was already at 2mm hub side. Now I am washing out later into the turn almost coming out of the turn. I am thinking it's over steering. Plan is to go 2.5 and see how that handles.
Track was dry but not too bad. The only thing now other 2wds were out so, I couldnt get a comparable time. I was running 30s mainly and couple of 28s. So I am feeling more confident with the adjustments made. The funny thing is went it is ran wet I know it will be dialed and may have to go with shorter links to make it a little quicker...lol....maybe.
Thanks, Guys for posting your thoughts and changes made for the car. I may just get the hang of 2wd yet.
The only thing I find odd is that when easing in the throttle then clamping it. It would torque steer and run into the wall. I dialed up some more punch control and that helped.
kstoracing1 is offline
Old 10-14-2011, 09:31 PM
  #10599
Motofan747's Avatar
Originally Posted by kstoracing1 View Post
Ok,
Hey i also had this problem. I was over rotating in the turns. My TLR buddy and I (mostly him) came up with 2.5 under inner and actually went to 0 degree caster and 2 shock eyelit turns on the front shock. I havent tried it yet but he texted me saying it was faster. I would give it a try.
Motofan747 is offline
  #10600
STLNLST's Avatar
Trader Rating: 31 (100%+)
Will this work for you? If not I can always take another one.
STLNLST is offline
Old 10-14-2011, 09:50 PM
  #10601
perfection...thank you very much a picture is worth a thousand words.
Old 10-14-2011, 11:21 PM
  #10602
twalace's Avatar
Originally Posted by TWRC View Post
Do you have a set? If yes, could you post up a pic of them mounted up
Here you go!
twalace is offline
Old 10-15-2011, 02:35 AM
  #10603
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Here ya go, you can paint the fake bead lock ring or paint juse the nubs that represent bolts.
Eli is offline
Old 10-15-2011, 05:52 AM
  #10604
JEDI BASS's Avatar
Trader Rating: 23 (100%+)
Default more info on my Losi ball diff disintegration
OK... so this was in my SCB, but Casper and others were asking about it here.
I installed a B-Fast in it an hour ago and was gonna reuse the gear. I hadn't noticed til then that the balls had torn into the plastic of the gear, like centrifugal force had wedged them deep into the plastic further from center. That partly explains why the outer edge of the rings were chipped away. Still not sure how this occurred (except for my daughters driving) or when it occurred: 1) during the diff's failure or 2) while I was trying to figure out (troubleshooting) what had happened by tightening the slipper and/or the thrust bearing.
Either way, love the B-fast and glad I ordered spares of everything for my 22 and SCB.
Now... off to the track I go .
JEDI BASS is offline
Old 10-15-2011, 06:49 AM
  #10605
Bonadona's Avatar
Trader Rating: 26 (100%+)
I have the B-fast pro kit with carbide diff balls and ceramic thrust balls. If built with care and broken in correctly, you will find it to be super smooth. This is the best diff I have ever felt and it's been run for weeks now. Nice job B-fast!!
Bonadona is offline
