TLR 22 Racing Buggy Thread
Taking a break from nitro I tried my hand at 1/10 onroad and it was pretty comical trying to break the "blipping" habit. You can always tell whos been running nitro
What is the best way to throttle an electric car?
1. Pump the throttle like a nitro kit.
2. Timed consistent pull.
3. Pull just enough to get moving, then hammer down to get up to speed.
4. On and off trigger (cant see this one working well)
I seem to be using 1, 2, and 3 currently. I think I may be better off with just 2 and 3. Beginners seem to use 4 mostly.
What do you use?
What do you use?
Has anyone built there shocks with the regular caps then gone to the rtr caps and felt or noticed a differance in how you buggy handles ,the reason im asking is my car is twitchygoing in and pushes mid to out ive tried all of the stuff people have suggested and its still the same ,thnx
The only thing you've changed is the shock caps?
Did you use the RTR o-rings as well? I feel that the cut bladders offered a better seal.
With your concern it sounds like the front of your buggy is to light. That will make it twitchy entering and pushy coming out. Are you running a shorty battery? have you added weight to the front of the car?
What kind of track is it and what tires are you running?
I think he means hes tried everything else but the rtr caps.
The caps should not change how the car feels at all assuming you bleed the shocks properly with both caps. Now I am obviously assuming you are running emulsion style (no bladder) for both setups. RTR caps are just way easier to bleed IMO.
I am looking to try a gear diff right now for the time being just to try one out. What oil would be best to start with? Looking to have it setup properly in the race track conditions. Track is usually watered heavily and locked down fast by the time 2WD Buggy gets on the track.
I've been reading 2k a lot, but thought I'd ask. Thanks.
Indoor clay I run 5k
I run on a small to med size indoor track that has a little clay my set up is this fr,55 27.5 red springs 3mm limiting middle top and bottom 25 and 5 c/l is in 1 w/2mm and none on caster block alum bulk head and brass kick shim, short batt w/ alum batt brace all the way forward rr, 55 25 unscrewed 3 turns mid on top out on arm white springs 1d w/2 mm under both ball studs trans raised 1 mm and for tires ive tried pink bk rr pink taper fr and pink tapers all around and green jcons barcodes v1 and v2 rips and barcodes on fr it seems no matter what tire combo i run it drives the same it has more rear traction than all of the rest of my friends 22's thanks for the help . and no bladders
Indoor clay, I'm running 3k in buggy. The truck is going to need thicker, probably 5-7k. Going to work on my slipper though this weekend on the truck and see if 3k will suffice. Didn't get time to experiment, just pulled from my 22 and installed in my 22t to run the main after I got barked at...
Anyone who says a gear diff in a 22 is a waste of time really needs to try one... Works well for me in buggy running mid motor...
Geared Diff
So I have a smart question from a dumb guy. Is the geared diff what comes in the RTR? Or is it something entirely different. I don't have a lot of spare time in between racing nights to spend tweaking on the car. I did read that the geared diff is pretty durable and doesn't need as much maintenance as the ball diff. Any help or suggestions would be greatly appreciated.
Here is link to video of my A main win on Saturday to get an idea of how well it works!
http://www.youtube.com/watch?v=Q5Ey1...ature=youtu.be
I did sand the case with 600 grit to help the seal. I run Mugen 1/8th scale, so I'm used to refilling diffs... lol If I can go through 3 race weekends and 2 practice nights maintenance free, that's a win in my book!
