rc8be 2650kv on 4s too much? >
Old 11-30-2010, 07:41 PM
  #16
Ostach24's Avatar
Trader Rating: 91 (100%+)
Way too much, most people are running 1700
Ostach24 is offline
Old 11-30-2010, 08:00 PM
  #17
devnull's Avatar
Trader Rating: 120 (100%+)
Originally Posted by Reubster24 View Post
Yeah i saw those and i'm thinking that and a 5s would be pretty nice! what you guys think? 33300RPM.
What size pinion would you guys use with the 44t spur?
With an 1800 I would personally start low (15 tooth).
My Losi 8ight-e 2 runs a 1700 with a 16 tooth and I run it on 4s (which is directly from the Adam Drake setup).
Last time I checked my name was not recognizable so I will use Adam's name LOL!
http://www.losi.com/ProdInfo/Files/L...6_DrakeStd.pdf
devnull is offline
Old 11-30-2010, 09:24 PM
  #18
funRC8E's Avatar
Default Wicked Fast.
I have the RC8E with 2650kv castle on 4s thunder power lipo. It is a really fast car and punch needs to be dialed down to control excess wheel spin. It is nearly impossible to hit the sweet spot on the track with the 2650.
I just recently sold my used 2650 for $70 and purchased castle's clearance 1800kv motor for $60 brand new.
The benefit of lower kv motors is that they run a lot cooler and allow for longer
run times. Lower kv has more lower end torque as well.
funRC8E is offline
Old 12-01-2010, 08:07 AM
  #19
b4maz's Avatar
Trader Rating: 8 (90%+)
I ran my RC8e on 4s with a 2650 geared 14/50 and it was fine. I ran that for about a year then tried the 1800 on 4s geared 19/46. The overall speeds are very close, but the 1800 is much smoother and easier to control. My 1800 gets much hotter than my 2650.
b4maz is offline
Old 12-01-2010, 09:14 AM
  #20
Reubster24's Avatar
Trader Rating: 37 (100%+)
Default Out with 2650 in with 1800
Will i decided to take advantage of castles deal on the 1800kv motor. Sold the 2650kv last night. Only thing is now i have to figure out how to gear the 1800 on 5s. Can you get a spur for the rc8 smaller than 44t? The largest pinion i can put on is a 18t because i have the tekno conversion.
Reubster24 is offline
Old 12-01-2010, 09:48 AM
  #21
Trader Rating: 20 (100%+)
You should still be able to run 1800kv on 4s okay. Just go to scriptasylum and calculate what you need.
quixoticboi is offline
Old 12-02-2010, 01:15 PM
  #22
Reubster24's Avatar
Alright guys i have been looking at scriptasylum and it brings up another question. How fast is good for racing. I wanna figure out what pinion to get and the tekno long shank pinions are to much to just buy them all. Thanks in advance guys.
Old 12-02-2010, 01:17 PM
  #23
Go for about 40mph. Also, make sure you calculate at full charge (4.2v/cell) and slightly less (4.0v/cell), because you'll discharge as you run. Some go around 41-42mph full charge and right at 40mph at 4.0v/cell.
Old 12-02-2010, 01:27 PM
  #24
Trader Rating: 19 (100%+)
40mph at most, but depending on the track, you may not really need more than 33mph or so. The one main outdoor track I run at has about a 175-200 foot front straight, so 40 +/- works very well. However, our indoor track which is pretty large with a 125 foot straight really doesn't need more than about 33mph or so
Edumakated is offline
Old 12-02-2010, 01:29 PM
  #25
Yes, indeed. Should have mentioned I was referring to a larger outdoor track (rev).
Old 12-03-2010, 04:40 PM
  #26
fishboy77's Avatar
Trader Rating: 16 (100%+)
Unless those calculators account for voltage sag I would plug in nominal voltage, about 3.7. No battery will maintain 4 volts/cell for more than a small fraction of the discharge even at moderate loads. 3.7 will give you a decent average voltage.
http://www.rcgroups.com/forums/attac...mentid=3385986
fishboy77 is offline
Old 12-03-2010, 06:26 PM
  #27
Mine usually get down to 3.7v/cell (or just a little lower) after one heat...
Old 12-03-2010, 06:38 PM
  #28
chris c's Avatar
Trader Rating: 60 (100%+)
Smile
So what would a 2650 on 3s be geared at??
chris c is offline
Old 12-03-2010, 06:39 PM
  #29
All depends on the car.
Old 12-03-2010, 08:07 PM
  #30
chris c's Avatar
Rc8be
chris c is offline
