RPM gear cover problem for the slash >
Old 11-27-2010, 08:04 AM
cbass722's Avatar
Default RPM gear cover problem for the slash
I got a slash 2 wheel and tried putting rpm gear cover on it and it dont seem to fit it seems like the shaft that comes out of the motor is hitting the cover like its to long. I knoe you cant run 90t so I put an 86t on and that didnt work anybody else have this problem
cbass722 is offline
Old 11-27-2010, 10:17 PM
cbass722's Avatar
nobody has had this problem please help
cbass722 is offline
Old 11-27-2010, 10:39 PM
I have a 90T on my 2wd Slash w/RPM cover;no problem. Are you using the XL5motor? Mine has VXL in one of them and CC4600 in the other. Even w/XL5 no problem.
bowl806 is offline
Old 11-28-2010, 09:48 AM
cbass722's Avatar
its a stock 550 12t motor i just dont get it. It just hits the shaft on the motor
cbass722 is offline
Old 11-28-2010, 09:57 AM
jeeperscreeper's Avatar
Trader Rating: 79 (100%+)
i had that problem with both a slash and an SC10,seems some motors have a little longer shaft, i just drilled a small hole so the shaft can come out of the cover
jeeperscreeper is offline
Old 11-28-2010, 12:06 PM
lowroad's Avatar
just leave the gear cover off! They don't do much to keep dirt out, but they sure keep it in.
lowroad is offline
Old 11-28-2010, 12:53 PM
agreed
the only thing i find them good for are the marshals fingers
Old 11-29-2010, 07:41 AM
cbass722's Avatar
guess its time to run coverless
cbass722 is offline
Old 12-01-2010, 09:20 PM
cbass722's Avatar
what about grinding the shaft down. Will this throw the balance off or something
cbass722 is offline
Old 12-01-2010, 10:04 PM
Henry#40's Avatar
You most likely have an older RPM cover.The original covers were shallower as the motor shafts used to be shorter before the XL5 models onwards.RPM made a running change to the covers to make them deeper to fit motors with longer shafts.
Henry#40 is offline
Old 12-02-2010, 05:44 PM
cbass722's Avatar
cbass722 is offline
Old 12-02-2010, 08:27 PM
Henry#40's Avatar
You can grind the shaft down without affecting the balance.
Just be sure to leave enough length to properly mount the pinion.
Henry#40 is offline
