Roughing up slipper clutch
Is there a method of doing this?
Sandpaper?
What grade?
Cheers!
Sandpaper?
What grade?
Cheers!
Location: Norwood, OH...and CCRCR and The OhioRCFactory
ThunderbirdJunkie likes to hit the aluminum discs with 1000-1500 grit sandpaper and wipe the pads themselves down with alcohol. Helps get a little more life out of them, which is great for us cheap folk
Super Moderator
Trader Rating: 31 (100%+)
I don't scuff the plates personally, if they were supose to be rough they would come that way I would think. I scuff the glaze off the pads on a foam sanding block. Can't give you a grit it's simply medium I work them in a figure 8 just like with diff. balls. It works and at $7 a pair it can save a bunch off $ for other stuff.
Suspended
I use 300 grit sandpaper to take the glaze off of the slipper pads. I made a little tool to hold the slipper pads so that way they get sanded evenly. To make the tool I take a worn out spur gear and cut all the teeth off with a dremel, that way when you put the slipper pads on it they stick out the furthest and are the only thing contacting the sandpaper. I've found that this tool is important for keeping the slipper pads even, and it makes it way easier to sand them because you have something to hold on to. Sometimes pad material is on the disks too, so I use a new razor blade to shave the pad material off of the disks. After all of this I clean everything with motor spray, and I make sure to not touch any area where the pads and disks meet so that way they don't get contaminated with oils from my fingers. I put everything back together and adjust my slipper.
I take care of both the slipper plate and pads. The pads usually don't need much, just enough to knock the shiny glaze off. I use fine and try not to remove much.
MT slipper plates tend to get polished and I get better performance from mine sanding them so they're not poilshed looking anymore. Use some 800 grit. Clean everything up with motor spray.
Cheers guys.
I am trying to eliminate a strange whining/slipping (almost grinding?) sound on WOT acceleration from stand still when I have decent grip (i.e. carpet), though roughing up the pads didn't really do much for it. I thought it might have been overly glazed pads. Something is definitely slipping.. It must be the diff?
R/C Tech Elite Member
Cheers guys.
