Old 07-17-2004, 11:56 PM   #1
Default B4 Question
Ok just got my B4 and got it all put together. Trying to figure out battery placement. I'm or was planning on using my batteries from my TC. So when I tried to install a pack I have to push them into place. The bars are touching on both sides. My problem/question is I thought it was bad for you batts to touch the chassis? I know on my XXX-S there is a thin strip of plastic you place on the chassis where the batts go. If I used something similiar to that however I would have to replace it every other battery cause the bars would easily wear it away.
What you guys do or know that can help?
Titan Racing is offline   Reply With Quote
Old 07-18-2004, 08:40 PM   #2
Aaron Waldron's Avatar
If it is the plastic chassis it shouldn't cause any problems. If you're worried about it (or if it's the graphite chassis) I'd pick up some chassis tape (AE sells sheets), or number-plate backing from the local motorcycle shop, and use it on the rails of the battery area.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-18-2004, 08:44 PM   #3
nutfluff's Avatar
Send a message via AIM to nutfluff
Actually, there are two sickers on the sticker sheet that are made to line the inside of the battery slot. They are the two black strips that say "RC10B4 Stealth" These two stips have notches on the bottom that correspond to the notches on the chassis. This isn't in the manual and you see a lot of people mistakenly put them on the body. But like Aaron said...with a plastic chassis you won't have any problems.....
nutfluff is offline   Reply With Quote
Old 07-19-2004, 02:33 AM   #4
Ybakoff's Avatar
I used a FT b4 on the weekend and one of my packs is very snug. It rubs on booth sides of chassis and you have to force it in and out.
I didn't have any problems with it. Only driver error.
Ybakoff is offline   Reply With Quote
Old 07-21-2004, 03:42 AM   #5
hawker's Avatar
wat do u think of the car? I'm down in australia, just ordered one from tower hobbies about half an hour ago, can't wait to get my hands on one
hawker is offline   Reply With Quote
Old 07-23-2004, 03:52 PM   #6
Hammer your battery bars flat. That allows a comfy fit.
beeoh is offline   Reply With Quote
Old 07-23-2004, 03:54 PM   #7
Ah
That's what those are for!!!
Old 07-23-2004, 04:44 PM   #8
Mr-s413bt's Avatar
Hey Hawker, the only change i'd make to the FT B4 is to change BACK to the plastic chassis.
The car seems more forgiving this way and a little easier to drive.
Glenn
Mr-s413bt is offline   Reply With Quote
Old 07-23-2004, 06:09 PM   #9
hawker's Avatar
ta for the advice!
Old 07-23-2004, 07:27 PM   #10
Ybakoff's Avatar
The factory team is quite good. My other B4 was close to FT anyway so I really didn't notice much difference.
What difference do you find with the plastic chassis. I have only used the other ones. Thanks.
Old 07-23-2004, 07:42 PM   #11
Mr-s413bt's Avatar
Heya Guys.
Well i have both and have run both over the last 3 months or so.
I prefer a graphite car but with a plastic chassis.
The plastic is a little more forgiving, you will gain a little traction especially here on the typically bumpy/slippery tracks we have here in Australia.
Most of the "TEAM" run the plastic chassis these days aswell, and yes there is such a thing as a too stiff chassis.
I find the plastic a little more consistent and a little less knife edged with the handling. It just seems to slow the reactions of the car that tiny bit making it easier to drive fast.
Glenn
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
