Reedy Modified Green Label
Hello, I recently bought a used slash and a non stock Reedy motor came with it. The guy said it was his old race motor that he geared down for his son. Seems to run good but slow. He had a 13T pinion on it to run slow for his son.
I am trying to find out what the spec of this motor is. There were no markings anywhere. How many turns? RPM? What pinion should I run for my slash?
You should open it if you really want to know what this motor is. It should be written on the rotor.
Or just gear up and check motor and ESC temps. As long as you can let your fingers on it, you are not overgeared.
Useally, there was a colored dot or star on the motor to help identify the wind, its possible its still written on the armature.
The Ultra series motors used the same dot and star color coding I beleive...
http://aedownloads.com/pdf/oldMRmotors.pdf
Take the armature out and there will possibly be a number written on the stacks in Magic Marker. If it's still there I can decifer it for you.
PM me or shoot me an email at [email protected]
