Old 07-15-2004, 05:06 PM   #1
hogdaddy77's Avatar
Default best engine 4 rc10gt
what is a good engine for running in a GT?
hogdaddy77 is offline   Reply With Quote
Old 07-15-2004, 06:12 PM   #2
Brian Miskolczi's Avatar
Trader Rating: 156 (100%+)
Your best bet would be to go with a OS cv or a OS cvr, both are great motors.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 07-16-2004, 01:09 AM   #3
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
How much money are you willing to spend, and are you bashing or racing?
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-18-2004, 01:01 PM   #4
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
Well if you are bashing and have a pretty big budget I would go with Ofna's Small Block 21, or this hpi Small block 18SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXGEE4&P=7
Smoke21 is offline   Reply With Quote
Old 07-18-2004, 07:14 PM   #5
nmt6789's Avatar
Send a message via AIM to nmt6789
You cant go wrong with a o.s .12 cvr or cvrx. Its a great engine and holds its tune.
nmt6789 is offline   Reply With Quote
Old 07-18-2004, 07:34 PM   #6
Any of the Novarossi based motors. I love my Nova. Has run trouble free for years.
groundhogg is offline   Reply With Quote
Old 07-18-2004, 08:47 PM   #7
Send a message via AIM to aoizip
sorry to jack the post... can ppl tell me are there any bigger fuel tank that will fit the car?? the stock tank is too small..... at least for bashing!!
many thanks!
~ming
aoizip is offline   Reply With Quote
Old 07-18-2004, 09:25 PM   #8
Aaron Waldron's Avatar
I haven't heard anyone putting bigger tanks in the truck. It's not too much to fill it up as you're driving it around
The tank from the Kyosho truck is quite a bit bigger, and you might be able to make it fit.
The carburetors on the O.S. motors are the best you can get in terms of reliability and ease-of-adjustment, which make them perfect for nitro newbies. A lot of big-name racers switch to O.S. carbs because of their consistency.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-18-2004, 09:29 PM   #9
thanks Aaron !! you da best!!
btw... for the O.S engin, if i have $200 to spend. what should i get? just spend the money on the engin itself? or spend wisly to buy a engin/pipe combo? mainly for bashing and part time racing.
thanks again everyone!
Old 07-18-2004, 10:52 PM   #10
The stock header and pipe are actually really pretty good matches for the CV-R. If you want a little more top end power, I'd buy the Losi Drake Edition pipe.
I'd lean towards the CV-R, and make sure you get the rotary carb!
www.liverc.com
Old 07-22-2004, 02:18 PM   #11
lizzardo420's Avatar
Sorry to interject but had to ask, you recomend the rotary carb for the Os .12 Cvr. would you please explain? Most of the top canadian drivers are using the slide carb then using exp on the radio to slow down the opening speed. Now I am confused???
lizzardo420 is offline   Reply With Quote
Old 07-22-2004, 02:25 PM   #12
Team Associated's Avatar
Send a message via Yahoo to Team Associated
Just go with a OS motor or if you willing to spend some money get a TEAM Orion WASP motor, they scream.
Team Associated is offline   Reply With Quote
Old 07-22-2004, 02:34 PM   #13
I presently race an Associeated RC10-gt factory team custom with the Novarossi c-12 side port with slide carb. Presently on gallon #6 on a 4yr old motor and runnin great. I just don't understand the rotory carb idea... I just thought I could learn form another persons experience, that is why I am hear. So much great ideas and experience can only be positive eh?
Old 07-22-2004, 06:01 PM   #14
Rotary carbs are less finicky when it comes to imperfect linkage settings. In order to obtain smooth and correctly linear throttle response from a slide carb, your linkage must be set perfectly..which is hard to do in a gas truck, especially the GT.
I would never recommend using exponential on your radio as a crutch to fix problems with setup or driving. It tricks your brain, as well as creates problems further on in the servo travel.
www.liverc.com
Old 07-22-2004, 10:10 PM   #15
Thanks Aaron
I apprecieate the info, and kinda makes more sense to me now.
rc10gt and a (p) shaft engine conatus Nitro Off-Road 1 04-15-2008 07:46 AM
Engine for my FT RC10GT, and T-Maxx ProMaxx316 Nitro Off-Road 1 02-06-2008 06:38 PM
rc10gt engine mounting Q NiTeHaWk4787 Electric Off-Road 7 08-10-2006 08:15 PM
How do I put a SG engine on a rc10GT? Striker Electric Off-Road 6 08-06-2004 02:39 PM
Best RC10GT P/S engine? NWDave Electric Off-Road 6 04-21-2004 08:56 PM
