Whats this sound and why? >
Old 11-08-2010, 09:01 AM
onekiwi's Avatar
Default Whats this sound and why?
HI all
I have just completed my electrical conversion of a cen matrix... Im happy with the results but before I shoot out and start shredding I have noticed an odd sound that Im not too sure should be there.
I think its from the motor
Its enhanced when it touches the diff
I have tried angeling the motor as I thought it might not be sitting straight.. nope no difference
Its only when its crawling and slowing once the revs come up it dissapears
I got this package: Team Novak 7.5 HV Pro 36mm Brushless Motor & ESC 3027
Any help is greatly appreciated
Now I see that I cannot post links to the videos as I haven't posted enough times
Ill see it this works replace the ** with tt or linkification if you are using firefox
h**p://s30.photobucket.com/albums/c338/simonandhanna/?action=view&current=MOV00359.mp4
h**p://s30.photobucket.com/albums/c338/simonandhanna/?action=view&current=MOV00358.mp4
h**p://s30.photobucket.com/albums/c338/simonandhanna/?action=view&current=MOV00360.mp4
h**p://s30.photobucket.com/albums/c338/simonandhanna/?action=view&current=MOV00362.mp4
h**p://s30.photobucket.com/albums/c338/simonandhanna/?action=view&current=MOV00364.mp4
onekiwi is offline
Old 11-08-2010, 09:49 AM
Rysuleod's Avatar
Is that pinion gear base touching the top motor case? It looks really close from the videos.
I'm not an expert but when the motor is cogging it almost sounds like the diff gear is bouncing in the pinion teeth. That's probably what is causing the additional noise.
I think you have it narrowed down correctly to the motor. Try taking off the pinion and spin it by hand to see how it behaves. Be careful about revving really fast it with no load because you can hurt your rotor.
Rysuleod is offline
Old 11-08-2010, 10:50 AM
onekiwi's Avatar
You can see how it behaves in one of the clips I think. the last clip
Yep theres a good 3-4 mm gap there
It doesn't run smoothly when Im spinning it slowly like its catching somewhere but when it gets a little speed it runs smoother
Im now thinking as I have a mod1 pinion, I took out the diff and rolled the pinion against the diff and it seems like it catches there, then I took the original clutch bell from the motor and that rolls smooth as silk
Can it be the mod1 pinion? Or is that just a meshing problem that a little driving will sort out
onekiwi is offline
