Will traxxas vxl esc run a novak 550 motor? >
Old 11-08-2010, 07:39 AM
phaqu22's Avatar
Trader Rating: 31 (100%+)
Default Will traxxas vxl esc run a novak 550 motor?
I am wondering if the Traxxas vxl3s speed control will hook up to and run the Novak 550 size motors.
phaqu22 is offline
Old 11-08-2010, 08:00 AM
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
no it wont. it wont because the vxl esc is not sensored
TraxxasPeter is offline
Old 11-08-2010, 08:06 AM
ZiG-87's Avatar
Code:
Motor Types  (Autodetect)        Brushed, brushless, sensored brushless
The aux port is the sensor port. Only the traxxas VXL motor is sensorless.
ZiG-87 is offline
Old 11-08-2010, 08:09 AM
phaqu22's Avatar
So can I run the motor sensored or sensorless?
phaqu22 is offline
Old 11-08-2010, 08:11 AM
pswag115's Avatar
The Traxxas VXL3S WILL run a novak 550. Not the best choice, but i've seen it done at the track by others. Just hook up the sensor wire as stated above.
pswag115 is offline
Old 11-08-2010, 08:12 AM
motor must be sensored to work. but seeing from the post after mine u can use the vxl
Old 11-08-2010, 08:19 AM
kufman's Avatar
The VXL can run a sensorless or sensored motor and you don't have to use the sensor harness for either one. In fact, from things I have heard in the past you may not want to run the sensor port on the VXL. I have heard that they early units had problems with sensored mode operation. Which turn of Novak 550 are you looking to run?
kufman is offline
Old 11-08-2010, 08:24 AM
phaqu22's Avatar
I want to run the 4.5 or 5.5 in a slash 4x4.
phaqu22 is offline
Old 11-08-2010, 08:56 AM
kufman's Avatar
The 4.5 will be rough on the VXL. If you try it, check your ESC temps often and adjust gearing as need to keep things cool. You may find that the VXL controller is a bit under rated for the 550 motors.
kufman is offline
Old 11-08-2010, 10:00 AM
Company Representative
I have seen this question before and I have asked about the motor limit/on resistance of the VXL.
Within our own controllers, we only recommend our racing escs----3.5T motor limit/0.00040 ohms on resistance----for use with our HV or Ballistic 550 motors. Especially the 4.5Ts. (GTBS, Havoc Pros, Havoc Pro SCs and Kinetics.)
NovakTwo is offline
