Tekin RX8: Has yours been reliable?
I am trying to get some legitimate data on the success/failure rates of this ESC. I have heard too many different things, from sources that I cannot put names to, to reach a definite conclusion. I am not one to believe rumors, hear-say, or dated information. Therefore, I want to ask any and all users of the ESC to report their experience(s) with it.
So, if you have used a Tekin RX8, please post the following information:
-Which version it is, including which motor
-When you got it/how long you've been using it
-The setup in which you used it (include car, voltage, gearing, and intensity of running; IE, bashing or hard racing)
-Any problems you have had with it
-Your experience with Tekin's repair service if you had to send it in
I am not at all bashing the RX8, Tekin, or anyone who may be directly or indirectly involved. It is not my intention to lead any potential RX8 buyers away from it due to whatever may be posted in this thread. The only purpose of this thread is to gather unbiased, statistical information.
I have 3 of them. The oldest was a 4 hole case that worked great for 3 months then had an issue and so I sent it in and Tekin's service was/is great. I highly recommend any and all of their products as they IMO are the best out and if any problem does arise they are quick to get it right with you.
I HAVE 2 RX8 AND HAD A PROBLEM WITH THE FIRST ONES OUT.... SENTI IT BACK AND NEVER HAD ANOTHER PROBLEM, THE RX8 ARE SMMOOTH EASY TO PROGRAM AND THE TEKIN SERVICE IS #1.... NO ONE IS BETTER. THE GUYS FROM TEKIN ARE HERE IN THE FORUM AND ONLINE ALMOST 24/7 TY AND RANDY WILL BENDOVER BACKWARDS TO GIVE YOU THE PRODUCT YOU PAY FOR. I RUN THE RX8/2050 IN MY 2.0 LOSI AND RX8/5.5 CS IN MY LOSI TEN SCT. I LOVE ALL TEKIN ESC'S AND RECOMEND THEM TO ALL THAT WANT THE BEST. THINGS HAPPEN, ELECTRONICS FAIL.... TEKING IS #1 FOR SERVICE AND PRODUCT! GO TEKIN!
WE BEAT THE CRAP OUT OF THEM AND KEEP ON GOING STRONG!
i had two of them both the old 4 hole case. i bought one had it for about3 months then i went to turn it on a race and when i fliped the switch, i got nothing just sat there. sent it in and it worked for about 3 months agian and samething.
used in a losi truggy 2250 motor 13p/46spur, 4s used for racing only, but it was only raced maybe twice a month, other then the not starting problem worked fine just was playing russian roulette on start up
bought mine used, it was the old style black heatsink four hole, landed a big jump flat and poof! i called tekin that day(a friday) explained to ty what happened and had a new 3hole red heatsink the following monday afternoon and have had zero problems since, and that includes hard landings,some cartwheeling and a few abrupt stops..........i run it with a 1700kv t8, 16/48, 5000mah 30c 4s............
Thanks for the input so far. Please keep them coming.
How do you tell them apart, where are these holes?
1. Rotor failed 5/09 after a few days of running. It was a well known problem and Tekin replaced it free no questions asked.
2. Motor stopped working 11/09. It was my fault though since I had the motor wires too short. After a while of "tugging" the solder had separated inside the motor. Tekin personnel fixed it for me at the event I was at.
3. ESC stopped working 6/10. Tekin replaced it with the new 3-hole case for a $40 charge. Quick turnaround time.
No problems since then. I run my buggy a lot so the RX8 has seen a ton of use. Overall, I'm very happy with the product and I would buy again. Tekin support is very good and I have had a ton of questions answered quickly from them. Since it is sensored, you get a very smooth running vehicle with it.
The stock fans don't last long. If you gear properly, you really wont need the fan. You can also upgrade to the ManicRC fans which are far more robust and last much longer.
I have been running the RX8 since march, I went through about 6 of them in two months and i was really pissed off. They replaced the two i had in for repair with the new 3 hole case RX8's in may. And since then i have beat the hell out of both of them with absolutely no issues what so ever. 6 months ago i wouldn't have recommended the RX8 but after they fixed their issue i cant say enough about them. the customer service alone is worth the money.
I have a rx8 that was fixed by tekin and have no problems with about 24 hrs of actual run time. I am getting another one soon, ill let you know how that one does as well.
