ammo box... (and a discharge/storage charge question) >
Old 10-27-2010, 05:54 PM
monkee's Avatar
Trader Rating: 15 (100%+)
Default ammo box... (and a discharge/storage charge question)
so after spending the summer braving it... just stacking all my lipos on a shelf and leaving them, i picked up an ammo box yesterday.
figured it'd be best to have them stored in there over the winter.
do you guys line the bottom and/or sides of the box with anything? or just toss them in there?
also as far as storage charges go, all of my batteries are fully charged.
not sure if its bad to store them this way for the next 3-5 months.
how is best to discharge them to half?
most of my batteries are 2cell 4k and 5k mah and 4cell 4k and 5k mah
and i have a couple flight lipos. both 1cell
my charger is a thunder ac6
thanks
c
monkee is offline
Old 10-27-2010, 05:59 PM
klaymon's Avatar
Trader Rating: 71 (100%+)
I put mine in a LiPo sack then in the ammo box with the lid NOT sealed to prevent build up of explosive pressure. If your batteries are fully charged, put them on a discharge cycle and set it for around 3.7V/cell cutoff then store.
klaymon is offline
smokinu's Avatar
Trader Rating: 65 (99%+)
discharge them to about 3.8-3.7 per cell..
about 80% charged that way they wont puff one you.. but i am sure 1 or 2 will.
and check them every few weeks to see if cells are droping voltage.
smokinu is offline
whitrzac's Avatar
Trader Rating: 96 (100%+)
your charger should have a "storage" mode...
usually you store them at 3.8v/cell
edit: curse you uber fast typers...
whitrzac is offline
Old 10-27-2010, 06:07 PM
monkee's Avatar
i dont have a lipo sack big enough to fit all of them...
4x4cell
6x2cell
2x1cell
and misc airplane lipos
does a closed box really create too much pressure? or can i just drill a small hole on the side of the box. leaving it open just seems to make my OCD tingle
do i use a balance board while discharging?
monkee is offline
Old 10-27-2010, 06:12 PM
monkee's Avatar
ok. so my charger discharges to 12v for 4cell.
so i just use the balance board and watch the cells and stop it manually at 3.7-3.8 ?
monkee is offline
Old 10-27-2010, 06:34 PM
1Fastpede's Avatar
Trader Rating: 52 (100%+)
i put mine in with bubble wrap. and i close the box because otherwise its pointless to have the box.
1Fastpede is offline
Old 10-27-2010, 06:49 PM
Trader Rating: 39 (100%+)
I had a couple of questions about this myself. I have an Onyx 230 and I don't even know if/or how it discharges. I have always just charged and never discharged. I had some Turnigy packs go tit up on me after I left them outside
after using them so I guess the cold dropped them below the volts required to maintain and they won't work no more. If I can't discharge should I fully charge, run them for like 2-3 minutes, balance again, then store?
Cody01 is offline
Old 10-27-2010, 06:55 PM
SaladFork's Avatar
Would that happen? They pack them with ammo without worry of explosive pressure. I use ammo cans, sealed. Just curious if that is actually the case.
SaladFork is offline
Old 10-27-2010, 07:12 PM
8ight-e's Avatar
Trader Rating: 58 (100%+)
thanks
c
I've had an ammo box for a couple years now to store my lipo's in (all yr around) I actually kind of lined mine.. my never used lipo charging sack is folded over getting the duties
LOL
PS as the others noted.. 75-80% charge for store. I check my voltage monthly and do a short cycle on them after 3 months (charge, then discharge to store (via my hyperion charger).
8ight-e is offline
Old 10-27-2010, 07:14 PM
monkee's Avatar
what'd you line it with?
monkee is offline
Old 10-27-2010, 07:15 PM
turbowop's Avatar
Trader Rating: 33 (100%+)
You guys are crazy. Thousands of LiPo's across the country sitting on shelves and hanging on pegboards in local hobby shops. I haven't heard of any going up in smoke.
Put them to storage capacity and throw them on a shelf.
turbowop is offline
Old 10-27-2010, 07:18 PM
SaladFork's Avatar
Those are brand new lipos... I have a wife, two kids and two dogs. I would never be able to live with myself if anything happened to them knowing it could have been prevented with a simple ammo can. For me it's more of a piece of mind.
Old 10-27-2010, 07:25 PM
monkee's Avatar
what amp to discharge? .5 is taking FOREVER
monkee is offline
Old 10-27-2010, 07:40 PM
Trader Rating: 21 (100%+)
Thunder AC6 can only discharge 5watts - thats all its going to be able to do, higher the voltage, lower the amp discharge rate.
You can put them in one of your RCs and run it down that way, will be way faster.
Duster_360 is offline
