antenna ?
Old 10-26-2010, 03:59 AM
ckblood05's Avatar
Trader Rating: 15 (100%+)
Default antenna ?
i accidently broke the wire on my rustler when i bought it. about 4-5 inches. the range is still pretty good. im going to the traxxas 2.4 when i get my income tax. but i added about 5-6 inches of like 14ga. wire. will that work?
ckblood05 is offline
Old 10-26-2010, 04:58 AM
Trader Rating: 21 (100%+)
Won't you be replacing the rcvr too? It will have a new antenna unless you have a 2.4 in there now. If you're going from AM to 2.4 the 2.4 is so short, you really need to get the rcvr box/antenna for the 2.4 as well.
Duster_360 is offline
Old 10-26-2010, 05:14 AM
ckblood05's Avatar
oh yea, im replacing the rx/tx both.
Old 10-26-2010, 05:36 AM
Suspended
Just get a Spectrum or some thing along those lines....The traxxas 2.4 receiver is the WORST receiver money cant buy.....Spectrum 3E set up is 100 bucks and will last....and it comes with a decent servo too
racerx1995 is offline
Old 10-26-2010, 05:58 AM
ckblood05's Avatar
really? i hear a lot of good things about the traxxas. $100 is a little pricey. the traxxas i can get for around $50ish on ebay new.
Old 10-26-2010, 08:16 PM
I bought a traxxas link 2.4 with rcvr on eBay for $46 shipped. Its been a nice radio, I've added 2 more rcvrs and it does a great job. I get a rcvr box and antenna tube for each one so the antenna gets setup and protected correctly.
The radio takes some getting used to since it doesn't have a screen, but the menu is straight forward and it works. Just about to get another rcvr for mine.
Old 10-26-2010, 08:18 PM
cobaltracer1986's Avatar
agreed. for a few bux more you can get a lot more radio that feels way better
cobaltracer1986 is offline
Old 10-27-2010, 02:04 AM
spektrums customer service and warranty alone are worth the extra $50, and u can get spektrum rx's for cheap on here and fleabay.
gatermaxx is offline
Old 10-27-2010, 02:35 AM
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
or for $3 he could replace the antenna on his current rx with futaba's 27mhz antenna wire.
But hell, who's counting right?
T-BirdJunkie is offline
Old 10-27-2010, 02:40 AM
SloRacer1080's Avatar
There's definitely nothing wrong with the Traxxas 2.4 rx/tx. Like Duster said, the menu is a little odd, but it's easy enough to learn and it does exactly what is needed. If you don't want to try to memorize the blinking light sequences, there is a little guide folded up that sits in the battery area of the remote. And I've seen the rx's go for as low as $35 before. I run them in all my rides, and have never had a problem. The only downside is the steering trim, you have to set the knob again when you change models. But that's where it shines sorta, no need to change model numbers on the radio, just turn on tx, then rx and it knows what car you're driving and adjusts its settings accordingly.
Personally I hate the way the Spectrum radios have damn near a full turn of steering either way. I love how the Traxxas radio is only about 1/3 a turn either way.
SloRacer1080 is offline
Old 10-27-2010, 11:59 AM
ckblood05's Avatar
well im definatley going with 2.4ghz. i think i will go ahead with the traxxas 2.4. it will more than likely only be used for my rustler.
Old 10-27-2010, 07:43 PM
Make sure you get the one that says Link - thats def the one to get. Traxxas made two, the older is the non - link one and it may be cheaper, but it does far less and is not the one to get. You want the 2.4 Trx Link radio.
Old 10-28-2010, 03:47 AM
ckblood05's Avatar
ok, i'll look for that one when im ready to buy. thanks bud.
