does anyone have a good t4 setup?
i was wondering if anyone here have a good t4 setup? are anyone using the plastic chassis?
YGPM ?
R/C Tech Elite Member
sent him a good t4 set-up-via pm
Y=you've
G=Got
P=Private
M=Message
Here is the set-up:
Chedda Bob T4 setup
Front:
shocks: #2 piston, blue springs, 5 limiters, 35wt oil, middle hole on the tower, inside on the arm.
camber links: outside w/ 1 washer on the tower, inside on the hub. 2 bumpsteer washers and the spindles in the middle
Rear:
shocks: #1 piston, green springs, 2 limiters, 27.5wt oil, inside hole on the tower, inside on arm.
links: inside on u-brace w/ 1 washer, middle hole on hub, hubs middle, 2* anti squat
notes: b44 rear hubs, 4 degrees of total toe in rear via my steel 4* squat block, 1/4 oz in each rear pocket of chassis, lipo weighs 8oz... no extra weight in vehicle, anywhere! truck is all graphite w/ plastic chassis.
Y=you've
G=Got
P=Private
M=Message
Here is the set-up:
Chedda Bob T4 setup
Front:
Rear:
