Old 10-16-2010, 07:28 PM   #1
Doxiedad's Avatar
Trader Rating: 29 (100%+)
Default Servo causing glitches?
Ran my XB808-E (nitro conversion) for the first time today. Ran into a problem where the esc and steering would keep cutting out on me. I would lose steering and throttle for a sec, then it would come back.
I put the buggy on the table and while running the wheels left and right I would see the light on the rx go out, then come back on.
I have a MMM with Castle 2200KV, Running 2x2s 5000mah 50C Losi Lipos, Spektrum SR3500 micro rx, and Spektrum S6030 steering servo.
I could hold the buggy up and give it all kinds of throttle and no problems, only with the servo.
I'm still fairly new to trouble shooting, but does this sound like the problem?
Tomorrow I'll get a video of it doing it on youtube.
Thanks.
Slash 2wd/Slash 4X4/DX3S
Doxiedad is offline   Reply With Quote
Old 10-16-2010, 07:53 PM   #2
Your answer is here... You need a $10 part and your problem is solved =)
http://www.rctech.net/forum/electric...s-problem.html
Dgee is offline   Reply With Quote
Old 10-16-2010, 08:01 PM   #3
Doxiedad's Avatar
Awesome, thanks for the help !!!!
Old 01-09-2011, 02:16 AM   #4
hey same happening with my car.
i try a diff servo and it works fine?
did u find the cap helped?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 01-09-2011, 04:35 AM   #5
Dlewis4's Avatar
Trader Rating: 148 (100%+)
The cap will solve all of your issues. P
It's a known problem
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 01-09-2011, 06:42 AM   #6
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
I run external Spektrum caps and my problem went away.....The servo is attempting to draw too much power
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-10-2011, 09:58 PM   #7
The problem is that the bec current and voltage settings in the esc are set to low. A cap may solve temporary. Another way to Fix this is to use a rx battery pack. When u pull triger it sucks power from rx this is due to Bec settings
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 01-10-2011, 11:13 PM   #8
KingdomRacer's Avatar
Also, make sure your steering EPA is adjusted correctly.
An improper end point for digital servos can stress the servo causing a higher draw in amps.
You'd be surprised how fine most of these servos can work with no extra help.
The cap does and can help if the steering EPA is correctly set.
It is of course another story with HV servos.
JESUS says, "Fix it B4 it Breaks, 'cuz a DNF is a SIN".
Alpha-RC.com/RcRenew.com/TritonRC.com
VPProUSA.com/UpGrade-RC.com/KalGard.com
Green-Gorilla.com
KingdomRacer is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
Glitches on Servo NOVICE4EVER Singapore R/C Racers 10 12-04-2007 09:24 AM
Can a servo cause a glitch? Iceracer Electric Off-Road 10 04-04-2006 02:07 PM
servo help!!!! ALBERTO Electric On-Road 19 09-18-2004 10:06 AM
