Brake and Torque Steer?? WHY!?!? Click on this Thread if you DARE! >
Old 10-11-2010, 07:33 PM
chonchachencho's Avatar
Default Brake and Torque Steer?? WHY!?!? Click on this Thread if you DARE!
Does it happen? Any tricks or tips on how to get rid of it would be... aweeeesome.
chonchachencho is offline
Old 10-11-2010, 07:54 PM
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Never really had it happen in 2 wheel. Back end wags around when you're too greedy with the trigger. Are you having issues?
The M03 would torque steer with a mild mod motor in it, but that's like...not the same
T-BirdJunkie is offline
Old 10-11-2010, 07:58 PM
Well i guess i shouldnt have included the Torque steer. I'm having most of my issues with breaking.. the back end always wants to swing to one side when braking in a straight line.. I find that applying to brakes gradually like you would the throttle helps.. but i wanna slamm on those things Hard!!
Old 10-11-2010, 08:36 PM
brickshouse's Avatar
Turn down brakes on esc or turn epa and or expo down on tx
brickshouse is offline
Old 10-11-2010, 08:49 PM
Trader Rating: 49 (100%+)
Yep, too much brake.
If it happens when on throttle it can be a binding outdrive or something of that nature.
aradaiel is offline
Old 10-11-2010, 08:55 PM
Yeah turn down your braking like the other guys said. Is it consistently going to one side, or does it change with sections of the track/wherever you're driving/etc?
Details on the car? gear diff? anything recently changed? Check to make sure camber is the same on both sides on the rear.
Old 10-11-2010, 08:56 PM
Briguy's Avatar
Trader Rating: 125 (100%+)
You have answered your own question .
Briguy is offline
Old 10-11-2010, 09:00 PM
thought that might be the case.. this happens mostly in my 2wd buggy.. in my short course it aint no thanggggg.. was thinking just now.. (im at work so i cant check) but i have a feeling the anti squat spacer backed off on one screws giving it different degrees causing it to give more traction to one wheel?
Old 10-11-2010, 09:25 PM
There's a couple guys in the SC10 thread saying their antisquat spacers are creeping out from under the toe block, so check that.
Pop some ballstud washers between the toe block and the T plate instead and you'll be good to go.
Old 10-11-2010, 09:48 PM
klaymon's Avatar
Trader Rating: 71 (100%+)
Nature of the beast. I've had it happen with every buggy I've owned and you can't tell me I had some kind of stuff coming apart in all of them to cause it. They've done when they're new. The back of the buggy is the heavier part. When you jam the brakes, that weight wants to lead the buggy. Think if throwing a lawn dart backwards. The heavy end will always swing to the front. The buggy is trying to do the same thing.
klaymon is offline
Old 10-11-2010, 09:57 PM
Neu_Racer's Avatar
Trader Rating: 211 (100%+)
If it does do it on power too I'd suggest looking at how tight your wheel nuts are on the front and rear. I had that happen a couple times. There is no real benefit to "jammin the brakes hard!" though.
Neu_Racer is offline
Old 10-11-2010, 09:59 PM
Dunno klay, the B2 never did that back in the day, and the B4 tracks pretty straight with the rear tires locked up.
And don't you dare accuse ThunderbirdJunkie of being a good enough driver to compensate for that, because that would be BS and lies
Old 10-11-2010, 10:03 PM
jaggededge's Avatar
When I first got a MMP I was smoking the tires on braking and kicking the rear around.
Lowered brake to 75 and it was a night and day difference.
jaggededge is offline
Old 10-11-2010, 10:08 PM
klaymon's Avatar
My B4 did it, XXX-CR did it, and my RB5 does it. You're just too elite for this thread.
klaymon is offline
Old 10-11-2010, 10:14 PM
LIAR!
