How much driving time do YOU personally get out of a 5000Mah Lipo ?
Just wondering what to expect once I get up and running..
Right now I'm still waiting for my low voltage cut-off in the mail, so I'm only running for about 10-12 minutes to play it safe, as I really have no idea how long it should last.
also , list your setup , I'm sure that has an effect on battery life..
I'm running a 2s 7.4V 20C 5000Mah Lipo on a bone stock Hpi Blitz SC 1:10
Awsome, If I get 25 minutes I'll be happy, I have one 5000mah now, and two on the way, 1.5 hours of runtime ain't to shabby .. ..
i get about 30-35min
i actually used it last night without charging for 2 rounds and a main
3300kv brushless in 1/10 truck
I see a little over 20 min in a CC Mamba Pro 4600 w/2s 5250 (and that's with some serious bashing on a dirt track.)
1 hour in the hpi formula ten with tekin 21.5,Losi 8ight-t 2.0e for 15 minutes with mamba monster 2200kv combo,45 minutes in the b4.1, 25 minutes in the jammin scrt-10 with mmp and novak ballistic 550 4.5t, 30 minutes in the t4 with novak havoc 8.5, 35 minutes in the b44, 35 minutes in the hotbodies d4 with novak havoc 8.5, 18 minutes in the hyper 9e with mmm 1800kv system.I think that's it lol.Oh and 30 minutes in the associated tc5 with lrp sphere 17.5 setup.
So would a stock blitz make the battery last longer than a smaller brushless motor ? or is the brushless more efficient and would use less ?
With stock setup in my Slash 4x4, I am getting over 15 min. I haven't really timed it, but definitely enough for a race. Now with the 13.5, I'm hitting 20 mins. easy. Using an 11T pinion, as the 13T was getting the motor way hot.
Get a 2 cell or more voltage meter like this: http://www.xheli.com/26cevomewlcd.html
Run the truck at your track, check the voltage often, and stop when the lipo reaches 3.7-3.8v per cell.
Recharge. If you put back in more than 80% of the lipo capacity you need to shorten your run times.
Ideally you want to stop early and work towards putting back 80% rather than shortening run times.
80% of 5000 = 4000mah
80% of 4000 = 3200mah
80% of 3200 = 2560mah
I've always stayed around 60% and my packs last for a long time.
