Need Gearing Help Fast!!! > Need Gearing Help Fast!!!
Old 10-10-2010, 10:56 PM
Divey's Avatar
Trader Rating: 109 (100%+)
Default Need Gearing Help Fast!!!
Here's what I got. RC8T FT Tekno conversion with a new 1518 1800kv motor. Using the 50T spur gear and will run on 4s and 5s only. I was initially running the 2200kv motor geared at 16/50 and it ran great. Now my question is with the new bigger motor what pinion size can I run? I have a 20T pinion so would that work or should I go down a couple teeth. Not looking for major speed and want to not worry about heat issues. Thanks
Terry
Divey is offline
Old 10-10-2010, 11:42 PM
CarlCrocco's Avatar
Trader Rating: 89 (100%+)
TTT, im curious as well
CarlCrocco is offline
Old 10-11-2010, 12:38 AM
Divey's Avatar
Well I went with the 20T pinion. I used the speed calculator and it is the same speed as when it was geared at 16/50 but with lower rpm's. It's almost 10,000 rpm's lower and on 5s I'm looking at around 50 mph. I did some more searching online and read that 20/50 is a good start with the 1800kn motor and I could even go up to a 22T pinion if wanted. I will try this out in the morning while checking temps and see how she runs.
Terry
Divey is offline
Old 10-11-2010, 10:31 AM
CarlCrocco's Avatar
How about on 4S,
and what's the torque like on that motor.
Old 10-11-2010, 08:52 PM
CarlCrocco's Avatar
I went with a 46/18 and it's perfectfor 4S.
