Old 10-21-2004, 08:33 PM   #76
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default If you buy the 7.5 K factory kit
you will have 4 ones that you cannot use the upper links are longer.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 10-21-2004, 08:36 PM   #77
FW-05RR's Avatar
Ultimate carries the mp777 Special 1 for $599.99
is that a good deal?
FW-05RR is offline   Reply With Quote
Old 10-21-2004, 08:56 PM   #78
TonyWest's Avatar
Default No thats not
Of course it is
Cost on the car dropped to like 530 so thats not bad
Some places are still asking for $650 plus
WALDORFRC.com
301-932-9193
Old 10-21-2004, 09:51 PM   #79
FW-05RR's Avatar
Default Re: No thats not
Originally posted by TonyWest
Of course it is
Im curious as to why the cost of the 777 dropped
Old 10-21-2004, 10:27 PM   #80
TonyWest's Avatar
Default Dont know
Good question though. I would just be happy.
WALDORFRC.com
301-932-9193
Old 10-21-2004, 10:35 PM   #81
FW-05RR's Avatar
Default Re: Dont know
Godd question though. I would just be happy.
Old 01-07-2005, 10:27 AM   #82
Motorman007's Avatar
Trader Rating: 80 (100%+)
what is the Short front upper arm part #?
thanx
Motorman007 is offline   Reply With Quote
Old 01-07-2005, 10:58 AM   #83
Manufacturer Stock#
IF329
short mp 777 arms
Old 01-09-2005, 01:38 AM   #84
Default 777 LSD question
Just upgraded from a OFNA PCR PBS car to a K 777 SP-1 and am having trouble with the handling of the car. Under power the car is so loose that it is impossible to drive. It handles flawlessly braking, coasting and under light acceleration but it is very unstable at full speed and under hard acceleration... the back end just wants to come around. I am running all suggested suspension settings from the instructions and am looking for some experienced input before I start making changes. It's got the LSD in the front, 4000 C and 1000 R. 22 Deg in front with 1.5 deg toe out, Rear has 3 deg kickup and 2.5 deg toe in. I have been told that many people replace the LSD front diff for a standard spider. Will this setle the car down under acceleration? Anyone have a similar experience? How'd you fix it? Are there setup sheets anywhere for diferent track surfaces? I can't find any. Thanks in advance for your help.
Danger Dietrich is offline   Reply With Quote
Old 01-09-2005, 01:45 AM   #85
I have already tried front toe in and out and it seems that 1.5 to 2 deg of toe out is the most stable. I tried 7000 wt in the center dif which made the car more unstable under acceleration than the 4000. I reviewed Yuichi Kanai;s setup from 2003 on the KIII and the only major difference from his setup to mine is that he runs 2.5 deg neg camber in the rear and I am running 1deg neg. I tried no sway bars, just front and just rear and it made no noticable change to the acceleration characteristics of the car. I have never had a car that steers too well to drive... Please help!!!!
Old 01-09-2005, 03:15 AM   #86
Couple of pro setups..
Here are Greg Degani and Mark Pavidis's setups they
posted here:
Response 5574:
Date: Mon, Oct 4, 2004 (23:46)
Got Back from Hemet car worked really well on Saterday, did lots of
testing with different set-ups. Finished third and almost won it but
crashed at the end..I had gotted lapped 7 minutes into the 15 minute
main by chad but i managed to put in fast laps in the last 7 minutes
and un-lapped myself and almost one but i blew it with 45 seconds
left..anyway Found a decent set-up for bumpy tracks. Diff
5000,7000,1000 Front oil 60wt 1.4 rear oil 35 wt 1.4 Front upper link
long, "High block""A" Middle steering hole on steering link. Shocks
inside on arm,inside on tower 14 mm ride hight clips front.
Rear end.. Shocks inside hole arm Second hole from inside on tower,
Use
the upper shock holes on the tower. 3 degree toe in,2 degree
antisquat.
Rear hubs back, use bottom hole hinge pin on hubs. 17 mm ride-hight
clips. Full travel front and rear(in the front yur travel is limited
by
the arms hitting the chassie...and in the rear your travel is limited
by the shocks in the top holes in the tower) So no need to mess with
your droop screws..Hope that covers it..
Response 5575:
Date: Mon, Oct 4, 2004 (23:48)
Oh and i forgot That set-up is for like 80 degree weather, if you race
where it is really cold like 65 and below reduce your shock oil to
like
50wt front and 25-30 rear...
From what i`ve read lately, Greg has also gone up to 3000 wt in the rear diff...
Mark Pavidis - 777 settup
front 60w oil (70w if hot out)
1.4 piston
blue spring
inside hole in front tower
inside hole for shock on arm
22 caster block
Low A block
std sway bar
ride height front bones just above level
5000 diff oil
steering in middle hole in rack
droop depends on track slightly limited
Center
48 tooth spur
13 clutch bell
3 shoe clutch 1.0 springs
7000
Rear
35 w oil
std rear sway bar
2 deg anti squat
3 deg toe
hubs back
camber link long and in lower hole in tower
2nd to inside hole in tower
inside hole in arm for the shock
blue springs
bones level if bumpy just above level
1000
go1d1e is offline   Reply With Quote
Old 01-09-2005, 11:06 AM   #87
Thank you so very much!!!!
Old 01-09-2005, 05:44 PM   #88
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
this is a add on for the degani setup.
#81 of 105 by greg degani (gregd) on Wed Jan 5 16:06:55 2005
Mike, Run 3000,7000,3000 for Kz. My car was really good there at the last races..Ive done a ton of testing with diffs the last month, Ive come to realize that you dont ever need to run an lsd in the front, all it does is make your car hard to drive through bumps and just in general. You can run a 3000 up front and turn-in like an lsd but still have the stability and ease to drive of a diff. If 3000 up front gives you too much steering run 5000 instead. Running 3000 in the rear is really the key to the 777. It calms the car down and give it super stability and traction out of the corners. If your on a super hooked up track like Hemet that also has a lot of bumps, 1000 in the rear will probably be better, but everywhere else run 3000.
cmain is offline   Reply With Quote
Old 06-11-2005, 10:43 AM   #89
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Exclamation latest VIDEO OF KANAI with his MP777 SP2
http://www.rcpics.net/member/Goliath
This guy took video of KANAI when he raced in taiwan race challenge(2005?). he got 8 video compilations..
but i like this video especially...
http://www.rcpics.net/media/MP777-SP2_video5.mpg
this video shows actually there is somebody is BRAVE enough to challenge KANAI for a few laps... but..... you see for your self! aiyaaaaaaaaaaa...
mop
mop_iko is offline   Reply With Quote
Old 06-11-2005, 03:24 PM   #90
tomdav's Avatar
Trader Rating: 42 (100%+)
Default Diff gears
Just wondering if the diff bevel gears have changed from the 7.5. I am going to change the TCD diff in front to standard and need to order some parts.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
F/T:Kyosho Kanai 2 with K3 set-up Tmaxx Montreal R/C Items: For Sale/Trade 8 05-20-2008 05:51 PM
Kyosho KANAI II with alot of hop-up's..Sirio kanai .21 rc_freak R/C Items: For Sale/Trade 13 11-07-2006 10:33 AM
kyosho kanai fs/ft blkmerlin1 R/C Items: For Sale/Trade 0 09-21-2005 10:33 PM
KYOSHO Kanai II Ron C. R/C Items: For Sale/Trade 4 09-10-2003 12:13 PM
Kyosho 7.5 Kanai II ed. chorner Electric Off-Road 36 07-27-2003 03:41 PM
