NEXX 8 Thread
Old 10-27-2010, 07:01 AM
  #166
Originally Posted by strodedawg
just put some of the parts i bought for the nexx on last night:
tekin motors do not fit because of the sensor port, even without spacer
rotated front plate to move sensor out of the way and trimmed the plastic portion of the port with an exacto.
not sure if i can run it sensored yet
will set mesh and find out
may have to cut shaft
my 3s lipos fit perfectly
cant wait to run this indoors
Uh, that's a problem. WTF! Ofna needs to get this info up on their website and onto their distributor's. If this is the case both of the motor options I was initially planning on using won't work. The HK motor is 74mm long and the HPI/Castle 2200kv I think is around 75mm. That really slims the options down for motors that will work in this car. That basically means using an L size motor like the 2650 CC or some of the Hobbywing motors. If this is the case Ofna seriously effed up. I just ordered this buggy two days ago, this aspect may have changed my mind. I was wanting to run a little lower Kv than 2650 and was considering a Tekin motor in the long run.
jediguru is offline
Old 10-27-2010, 07:11 AM
  #167
strodedawg's Avatar
Trader Rating: 85 (100%+)
i think they designed the buggy around the castle motors, as you can see all of the vehicles are offered with a castle set-up. and most pictures show a castle set-up in. nothing a little work can't fix.
but the optional motor mount is a must in my opinion
strodedawg is offline
Old 10-27-2010, 07:32 AM
  #168
Hmm, they need to put max motor dimension information in the description. Yeah, on nitrohouse they have it with the 2650kv motor installed. I was thinking of possibly running something closer in the 2000 to 2200 range, enter Tekin. So you think you can get yours to work, you going to run it sensored or unsensored? I'll wait and see how the stock mount performs. Are you talking about the Grid mount that is in the works?
jediguru is offline
Old 10-27-2010, 07:44 AM
  #169
strodedawg's Avatar
i think it should work just fine give me a day or two. if u look at the hop-ups the mount for the jammin is avalable and fits nicely. i do believe that the max motor length is stated on the site somewhere and in the manual. that with the spacer though. remove the spacer and the stock mount should fit perfectly i think. never tried just put on the jammin one . the only problem is cutting the shaft a few mm for clearance
Old 10-27-2010, 01:26 PM
  #170
Oldanski311's Avatar
Do you think the chassis will be an issue for regular racing with medium sized jumps?
Also would I have to run a 6v servo voltage regulator if I use 14.8v of batteries?
Oldanski311 is offline
Old 10-27-2010, 01:32 PM
  #171
carcrazy699's Avatar
Trader Rating: 49 (100%+)
ok guys thinking of going to nitrohouse today and grabbing one of these.
is there anything i should know about this buggy before i get one? i am new to 8th buggies but not to 8th since i have a truggy also. thanks
carcrazy699 is offline
Old 10-27-2010, 01:34 PM
  #172
lbckevin's Avatar
Trader Rating: 107 (99%+)
Head over to West Coast ...we have them in stock
lbckevin is offline
Old 10-27-2010, 01:40 PM
  #173
Originally Posted by lbckevin
Head over to West Coast ...they are only $249.99
pm sent to you
Old 10-27-2010, 02:13 PM
  #174
scoobie1's Avatar
Will batteries w/bullet type connectors fit in the tray without modification?
scoobie1 is offline
Old 10-27-2010, 04:27 PM
  #175
trx-1racer's Avatar
I had the same question and found that the pictures in the manual posted at Nitrohouse appear to have cutouts for simple connection of the 4mm plugs.
trx-1racer is offline
Old 10-27-2010, 04:30 PM
  #176
man i want one.
tacomaster is offline
Old 10-28-2010, 03:46 AM
  #177
strodedawg's Avatar
finishing putting some of the ugrades i bought. some minor issues came up:
1- graphite steering plate did not have a hol for the chassis brace - easy fix drilled a new one
2- cnc steering rack w/ bearings : rack screws did not fit in bearings had to reduce the diameter of one screw by.2 mm
other than that good kit
buying some cmc suspension blocks and the lighter chassis in a few weeks after some testing
Old 10-28-2010, 05:00 AM
  #178
8ight-e's Avatar
Trader Rating: 58 (100%+)
1515 sized motors are waAAAAy too much motor for a buggy anyway. The 1512 1800kv is the best option.. the 2650 is a little too much kv iMO. Any of this size motor is perfect in a buggy.. you could even go a little lower depending on your skills and track. The tekno lektron motor I run is a touch smaller than the 1512 and is PERFECT, the best motor/setup i've ever had in a 1/8 buggy.
8ight-e is offline
Old 10-28-2010, 06:18 AM
  #179
Yeah, I hear you there and would agree, I just was a little low on cash and wanted to get it up and running before I invested in a dedicated power system for it. I actually have looked at the 1800kv as an option on 4S but wasn't sure if it would have the top end I would like to have on the larger tracks I go to sometimes or for the occasional bash session. I was considering getting the 2650 in either the CC or HPI variety or possibly a Tekin if it can be made to fit; but I am completely open to other options. I will likely run a MMP or possibly a MMM on 4S. Anybody else have their two cents they'd like to chime in with?
Castle has the 1800kv on sale for $60, man that is a steal. What do you guys think?
jediguru is offline
Old 10-28-2010, 08:56 AM
  #180
ebasher219's Avatar
Where!!!
ebasher219 is offline
