Killed my b44 diff. >
Killed my b44 diff.
Killed my b44 diff.
Old 10-06-2010, 03:14 PM
kman16jr's Avatar
Trader Rating: 56 (100%+)
Default Killed my b44 diff.
just killed the diff in my b44,so what will i need to rebuild it?It sounds like the gears are done.I will be buying a new ring and pinion tomorrow,what else will i need?
kman16jr is offline
Old 10-06-2010, 03:37 PM
simplechamp's Avatar
Trader Rating: 73 (100%+)
Might need diff balls, rings, screw and nut
simplechamp is offline
Old 10-06-2010, 03:39 PM
kman16jr's Avatar
yes it does,i'm already getting the gears for it tomorrow,just wondering what else i need to replace when i rebuild the diff.How is the truggy doing?
kman16jr is offline
Old 10-06-2010, 03:41 PM
Truggy is going strong, haven't had much time to drive it lately. Wanted to put a 1520 in it, but wouldn't fit so sold that and got a 1518, hope to put that in and get a few runs in before winter comes (which is like 2 weeks away for me LOL)
Old 10-06-2010, 03:43 PM
kman16jr's Avatar
Better hurry up.My truggy doesn't even have it's motor right now.I need a 2200kv motor now.
kman16jr is offline
Old 10-06-2010, 03:49 PM
Trader Rating: 104 (100%+)
You can download a manual offline, but generally just gears screw spring rings balls for a diff. You probably just need the gears balls and rings though
Ostach24 is offline
Old 10-06-2010, 03:51 PM
kman16jr's Avatar
Well the car has only had about 10 packs through it,if that.so i'm thinking maybe just the gears.I will get the diff. balls for the future when i need to do a full rebuild.
kman16jr is offline
Old 10-06-2010, 04:10 PM
rcgod's Avatar
Trader Rating: 33 (100%+)
If it was the rear diff check your slipper. I used to tear up rear diff gears in mine if I ran the slipper too tight.
rcgod is offline
Old 10-06-2010, 04:19 PM
kman16jr's Avatar
I did adjust the slipper today.that might have caused it to tear up.I will reset the slipper with new pads because they might need to be replaced as well.The slipper and diff will be set to factory settings so i know i'm not doing anything wrong.
kman16jr is offline
