shocks
shocks
how in the heck does the shock rebound?
I just don't get how it works
how does the piston get forced back down in the body without the spring?
* With the exception of bleedable shock caps
Its actually the air in the shock bladder compressing, the shock oil as a liquid cannot be compressed. A good example, build a shock with zero rebound(Fill with oil, bleed out the air, push the shock shaft all the way up put the bladder on and screw the cap on). The shock shaft will now rebound around 30-50%, but pull the shock shaft the rest of the way out and the vacuum pulls it back in.
