Tekin 2050 overheating on 4S
#61
Ok, so just a quick question. i have a losi 2.0E geared 15-45T tekin 2050kv with MMM ESC. I am able to get just over 20 minutes with this setup, and at the end of the 22 minutes, the motor is about 180F. Is this fine? If not, gear up 1 tooth, or down? Wiull be for a fairly large open track
#62
Leave your gearing, 20 minutes and 180 is fine.
#63
i was disappointed with my motor today, was racing and the entire back section of my motor came off. i thought it was just me but i had about 10 people tell me that they have had the same issue.
I think Tekin needs to rethink their design for the motor case, maybe something bigger where you can put a decent screw instead of those tini tiny things they call screws to hold the back on.
Motor has never been overheated, i have always checked it for loose screw and i even used lock tide.
#64
Motor back plates don't come off often at all. If you maintain your motor from time time time this is easily prevented. I find it a good practice that if I'm changing the center diff oil for example, it's time to service the motor. A drop of blue loctite on each screw when going back together.
#65
180f is fine all day long. 160 doesn't mean he's over geared at all.
#66
You may also say that i does not happen often but when i have 10+ local drivers come up to me and tell me that they have had the same issue then i am worried, specially since i have only had this problem with the new motor.
#67
Arthur, don't defensive at all. You must understand that while I'm addressing you I also know 20 other guys will read this.
I'd like to see your motor, send me some pictures: [email protected]
#68
I am looking for more power out of the 1900kv
I got a 17/44 TEKNO eb48.2. Temps are 149-150 is the most I have seen on the motor an 103 with the fan on or cooler?? 4s 5000mah Smc lipos.
I am running profile 3
#69
How big is your track? Your temps tell me you can gear up a tooth...
#71
I will do that today, will send it in as well for service and i could address you if you like. That way you can take a better look in person.
#72
Having a overtemp problem. thinking it may be an under geared issue.
Tekin 1350kv on 6s in a truggy. new vehicle, nothing binding. ambient temps high 90's F
RX8 gen2 factory settings other than reverse rotation. no sensor wire.(no room)
spur48/pinion 12 . also had a 13 pinion not much change in temps.
diff 43/10
FDR @17.5
Temps pushing 200F after15 mins.
6500mah 70c rating
fairly technical track. 130ft straight
doesnt fade .no thermalling
diff 43/10
FDR @17.5
6500mah 70c rating
#73
Team Tekin
diff 43/10
FDR @17.5
6500mah 70c rating
diff 43/10
FDR @17.5
6500mah 70c rating
What kind of vehicle?
#74
diff 43/10
FDR @17.5
6500mah 70c rating
diff 43/10
FDR @17.5
6500mah 70c rating
