are there any hex adapters for sc10?
Pro-line has a kit for front and rear 12mm hexes, but they require the 0 offset protrac rims for proper width to keep the wheels tucked under the body. Several other companies make rear hubs and you can also use the blitz front knuckle assembly I beleive.. but again you need the 0 offset rims for proper width.
You could also get the 17mm adaptors from AKA and use the 17mm short-course wheels from DE racing.
