AE B44 vs Durango DEX410
#17
#19
durango all the way
#20
Had a B44 and didn't like it. I was too scared to push it due to the fragile frot end
With my Rango, I am SOOoo much faster. The car inspires confidence. If you have the aluminum front arm mount, the car is bombproof. So, that is one less thing to worry about. The far just won't break!' I have hit many pipes and walls that would have rendered any 4wheel useless, and I just kept on driving
The car carries more cornerspeed than anything I have err see. On power, off power, it goes where YOU tell it. It also jumps asgood as an 8th scale. Maybe that's because it is one...in 10th form
And one last thing? Parts are cheap very. Cheap
As my friend would say, you have to stay on top of the car (b44) and think about it. The Durango just...does.
Works for me!
Works for me!
#21
Dont let the metal chassis of the durango fool you. While it's a brilliant piece of kit it has it's draws backs. While the arms might be tougher then the B44 the drive line has a tendency to fail. The weak point is the CVD couplers. They require a steady diet of pin replacement.
If your worried about a B44 having a fragile front end heres a pro tip. SUCK LESS and hit fewer things
Serioulsy with the high end Lipo and Brushless motors in these little cars that are capable of 1/8th buggy speeds on a smooth track it's no wonder they shear parts off on impact. My home track is a LARGE 1/8th layout and we race 4whl mod regularly on it. We have 2 20' plus Big doubles. The B44 takes it in stride as long as you land on all 4. I've seen a few Durango's not finish mains before.
#23
they fixed the pin issue on the durangos...they now use a 2mm pin instead of a 1.5mm pin...2010 spec and the r have these cvds on the car...that's the only problem i've heard about on the durango...still need to run my durango....i may upgrade all my cvds later
#24
hinge pin holders need swapped, ballcups/studs need swapped, rear ring/pinion issues, the car is nowhere near perfect, 1 seasoned racer has already given up on his and we have'nt even got started.............good car, but like everything mechanical, it has it's quirks....
#25
#26
Everything breaks that's for sure and if you crash on continuous basis and won't maintain your car you'll break even more. Fact is that the driveline pin issues have been addressed, many racers change ball cups and studs on other cars like AE, Tamiya, LOSI so you can do that as well on Durango but again it's not needed etc. Only real "issue" if you want to call it like that is the plastic front hingepin holders of the R model. They are a bit fragile but again it's the same thing as B44 front end, if you crash you'll break. If you change the holders to alu then the car holds even you suck yourself so it's not the car's fault.
All in all DEX is probably the most bullet proof 1/10 scale car out there. It can take a lot of abuse when compared to any main stream car but again it's not unbreakable as nothing is. It's a strong contender and when people start to realize it can make the mid pack drivers shine they start to be scared and badmouth the product + there is always these internet/forum clown who have no clue but they know everything since they have red it somewhere. Car is good, it's not the best for everyone as people prefer different things but it's fast
#27
Originally Posted by [email protected]
The 410 or the 410R? There shouldn't be any rear ring/pinion issues if it's shimmed properly, but I have the 410, not the R. I only broke a servo saver first time out, otherwise it seems pretty bulletproof.
#28
The 410r isn't as bullet proof as a lot of you think. I've had nothing but issues with it so far. I've changed the hingepin holders, the rods/ends and ive broken a few servo savers. I found that my servo saver was self-loosening causing it to self destruct. I'm finnaly to a point where I think I'll be able to finish a race.
#29
You must not have put threadlock on the servo saver nut... like the instructions say.
I have had no issues. I got stuck in the 8th electric class and took 3rd.. and a hell of a beating... and finished every race and qualifier.
This car is bulletproof, if you build it right and add the arm mounts.
