Old 09-25-2010, 03:45 AM   #1
Trader Rating: 4 (83%+)
Default 1/8 Buggy Battery C Rating Help/Gearing Help
I have an RC8Be with a 2250kv motor and 80amp ESC (Xerun).
I've lost 4X 20C 5000mah Zippy Flightmax Lipos to puffing because the batteries got HOT. And I mean as hot as NIMH batteries do.
I only have 2X Tenergy(Not Turnigy) 5000mah 20C left. And they get REAL HOT. Like steaming hottub hot. They had about 100 runs on them by now I got them in April or Early May this year. They finally started to puff, but very slightly. After all those hot runs in the heat they took a big beating. And I bash crazy. Slammed my buggy down onto the concrete time after time.(Not as much anymore.)
Anyways I ordered a 30C lipo, would this get as hot? I'm geared with a 13T pinion, 46T spur(stock). I hope I am no undergeared causing the heat.
Let me hear you thoughts, thanks again.
DriftWoof is offline   Reply With Quote
Old 09-25-2010, 03:57 AM   #2
smokinu's Avatar
Trader Rating: 60 (98%+)
the 30c should not puff.
20c in anythong other then a 10th is not enough.
these big 1/8 systems eat up the amps!
30c minimum!
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 09-25-2010, 05:45 AM   #3
Yes, you need 30C (30 x 5000mAh gives 150A, and you can pull 80% of this).
But you appear to be under-geared. I would guess 15T would be better.
stigno is offline   Reply With Quote
Old 09-25-2010, 05:51 AM   #4
I figure a 15T would make it run hotter. I thought undergeared was about 11T I am going to change it in that case. I am glad that I went with 30C, I was new to the buggy world when i bought the 20C also they were dirt cheap locally.
Old 09-25-2010, 05:52 AM   #5
morgoth's Avatar
Undergeared makes your motor hot, not your batteries
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 09-25-2010, 02:29 PM   #6
Great, thanks for your time help guys
motors, batteries, esc's, ratios kingsnite Electric Off-Road 6 06-23-2010 02:50 AM
