Which Novak ballistic 550 to get? > Which Novak ballistic 550 to get?
Old 09-23-2010, 09:07 PM
Default Which Novak ballistic 550 to get?
I have a hyper 10sc and I am getting a ballistic 550 motor. Not sure which one though 4.5, 5.5, 6.5 what do you have what are the main differences?
Hottaco is offline
Old 09-23-2010, 09:15 PM
mcheroke's Avatar
Trader Rating: 15 (100%+)
just get the 4.5, everyone else is running that
mcheroke is offline
Old 09-23-2010, 09:16 PM
imaxx21's Avatar
power....
get the 4.5
imaxx21 is offline
Old 09-23-2010, 09:56 PM
turbowop's Avatar
Trader Rating: 33 (100%+)
I like the 4.5t with the 14mm tuning rotor. Brings the KV down to about 4000, so go up a tooth or two on the pinion and enjoy the crazy torque. Only downside is the added drag brake effect due to the stronger magnets, but it's manageable, IMO.
turbowop is offline
Old 09-23-2010, 10:01 PM
ZiG-87's Avatar
I run a 4.5 in my hyper 10sc. Stupid fast. On pavement it can pull a 10 foot wheelie with 7k weight center diff oil. Enough power to spin all the way down the straight at the local club, but I can also dial that back a bit with the endbell timing. I think it's perfect.
ZiG-87 is offline
Old 09-23-2010, 10:04 PM
smokinu's Avatar
Trader Rating: 60 (98%+)
i ran the 5.5 that is until it seized a front bearing.
pre ordered a Tekin 5.5 the next day.
I run the 5.5 through an rx8, and timing it to about 20-25 and it pulls 4.5s down the straight and i still have room to gear up on bigger tracks.
smokinu is offline
Old 09-24-2010, 09:08 AM
Company Representative
You could have emailed us your serial number and date of purchase and requested a replacement bearing, if still under warranty, we would have just mailed you one. The Ballistics are completely rebuildable and parts are always available; makes the motors simple to repair. The bearings in BL motors must be inspected and cleaned occasionally; we even made a video:
Novak Channel: How to Clean your Brushless Motor
NovakTwo is offline
Old 09-24-2010, 11:39 AM
smokinu's Avatar
i will email you right now..
i love the way the novak ran! and i only raced it 3 times and 4 practice days.
i shoot you an email i want to get this truck back on the track it will be another month or so before i get my tekin (WAY late pre order)
Anyways..
about the balistic parts.. could i replace the rear end bell on my 5.5 to the balistic one? that way i can run a regular sensor cable?
Picking up these parts to do it
Back end bell
Bearing cap
Timing/sensor port
and the Insulator pack
smokinu is offline
Old 09-24-2010, 02:52 PM
Anyways..
Back end bell
Bearing cap
Timing/sensor port
I am assuming that your 550 was the older HV version. There are some parts that are the same between our old HV 550s and our new Ballistic 550s, but the back end bell isn't one of them. See the diagram at the link. If you have questions, you can PM me, too.
NovakTwo is offline
