Hyper TT 4wd 1/10th Truggy Thread >
Like Tree26Likes
Old 11-05-2017, 06:10 PM
  #4141
rustler1995's Avatar
Trader Rating: 24 (100%+)
Solid tuning session today, Truck is better than ever. More and more people are getting interested in them again. Hopefully they make a comeback!
rustler1995 is offline
Old 11-05-2017, 06:20 PM
  #4142
RazorRC's Avatar
Originally Posted by AnonymousUser View Post
Nice electronics layout. What are you using for a battery strap?
RazorRC is offline
Old 11-05-2017, 06:29 PM
  #4143
AnonymousUser's Avatar
Trader Rating: 21 (100%+)
Thanks. Iím using battery hooks for a Yokomo YZ-4 from Bezerk RC with 3mm ballstud washers underneath so thereís room for the Velcro strap to pass through underneath. Battery is a Turnigy 2600mah 90c Super Shorty, I believe LRP and a few others make one too. Gets about 10 minutes of run time.
AnonymousUser is offline
Old 11-07-2017, 08:24 PM
  #4144
Couple laps from the other night before I started tuning on the shocks. Running 40/35 oil now and not nearly as much chassis slap. Apparently the newer kits come with 4 hole pistons.
+ YouTube Video
Old 12-04-2017, 10:27 AM
  #4145
motoj550's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rustler1995 View Post
Hereís my ride so far.
Reedy sonic Mach 2 8.5 540 can with 13t pinion
Muchmore Fleta Pro esc
Hitec 985
Running 5-5-3
FRONT: 35wt with Associated Truck Grey spring
REAR: 32.5 with Associated Truck Green spring
Running proline electrons with proline closed cell foams.
Still playing with shock positions, will update after practice sesh.
do you have the part #'s for the associated front and rear springs?
motoj550 is offline
Old 12-04-2017, 11:41 AM
  #4146
Fronts ASC91637
Rears ASC91639
Old 12-04-2017, 02:53 PM
  #4147
motoj550's Avatar
Thanks man, right now i'm runnin losi tlr springs with rates at 2.0 in rear and 2.9 in front and seems to might be just a tad soft but it is working really well. it's wanting to balloon the front tires on the straights and then when i get on the brakes for say a 180 turn it wants to hook and spin out so thats why i think springs are little soft. looks like your running a really stiff spring in front, is it hampering your turning any? i also made a 1.6mm front swaybar out of music wire, stock i think is 2.0mm
motoj550 is offline
Old 12-04-2017, 07:00 PM
  #4148
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
This could also be a center diff that's too light. What oil do you have in the center currently?
billdelong likes this.
Matthew_Armeni is offline
Old 12-04-2017, 09:46 PM
  #4149
motoj550's Avatar
I'm runnin 5-5-2
motoj550 is offline
Old 12-04-2017, 09:51 PM
  #4150
RazorRC's Avatar
I didn't like the front swaybar on my Hyper TT on any kind of surface (loose outdoor or high-bit indoor clay), I recommend getting rid of it.
After doing a lot of testing with different diff fluids, I liked 10k/40k/7k diff fluids on high-bite indoor clay and 15k/80k/15k on outdoor, loose dirt when running a fairly fast SMC 4500kv 4-pole motor.
Indoor clay setup tips:
+ YouTube Video
Outdoor loose dirt setup tips:
+ YouTube Video
RazorRC is offline
Old 12-06-2017, 06:53 AM
  #4151
Check out the new Hyper 10TT group on Facebook. Feel free to join and post up your setups!
https://m.facebook.com/groups/182769...?ref=bookmarks
Just joined thanks!
rustlerfan47 is offline
Old 12-07-2017, 04:48 PM
  #4152
motoj550's Avatar
Here's mine, just got 4 packs through it at the track and lov this thing, i'm hooked! boiled all the parts 1st and had a few hard crashes and nothing broke. bumped my shock oil up 5 more weight front and rear and some of the front tire ballooning went away and the hooking and turning calmed down a little too, got a little stiffer springs on the way, been running losi 2.00 rate in rear and losi 2.90 rate in front. gonna try losi 3.40 front and associated 2.40 rear next.
Attached Thumbnails Hyper TT 4wd 1/10th Truggy Thread-20171202_145609.jpg   Hyper TT 4wd 1/10th Truggy Thread-20171202_145736.jpg
motoj550 is offline
Old 12-14-2017, 11:48 AM
  #4153
motoj550's Avatar
Ran the 3.40 front and 2.40 rear springs last night and man what an improvement, this thing is awesome, think i might bump front springs to associated 3.75 for next weeks practice, front still seems a tad soft still. and now 3 weeks runnin and still nothing has broke yet!
motoj550 is offline
Old 12-16-2017, 11:10 PM
  #4154
Right on man, what motor/esc are you running? Full size pack or shorty?
Old 12-17-2017, 11:00 AM
  #4155
motoj550's Avatar
Mamba Max Pro esc and SMC racing 4500kv motor with 12 tooth pinion and runs bout 110 - 120 temp on full battery pack on our local indoor clay track longest straight prob about 40ft, runnin Gens ace 5000 hard packs.
motoj550 is offline
