Old 06-26-2004, 06:37 PM   #1
racen 77's Avatar
Default B4 steering
How can I get more high speed steering without affecting or minimumly affecting low speed steering? 30 degree caster blocks seemed to help some but I would like a little more. Would switching from 3 degrees anti squat to 2 help? Maybe a little less rear wing angle would be better. Any help would be appreciated.
racen 77 is offline   Reply With Quote
Old 06-26-2004, 07:01 PM   #2
nutfluff's Avatar
Send a message via AIM to nutfluff
It would help to know your setup. Springs, pistons, shock oil and shock positions....
nutfluff is offline   Reply With Quote
Old 06-26-2004, 07:30 PM   #3
racen 77's Avatar
Post
Set up is pretty much stock team kit. Only differences is # 2 pistons all the way around, 35 wt oil in front shocks, and upper rear shock mounting in inner most hole.
Old 06-26-2004, 07:41 PM   #4
nutfluff's Avatar
Go to Brown springs in the front. Green in the Rear and #1 pistons all around. This is pretty much what all the factory guys use as a baseline. If you really want to do some reading on the subject go to www.rc10b4.com and search the word "steering" This is the premiere B4 site that is frequented by the important associated drivers. Make sure you do a search first before asking.
You will find what I suggested to be the first thing to try.
Good Luck.
Old 06-26-2004, 07:56 PM   #5
racen 77's Avatar
Don't know if I'm ready to make such a big change. I like the feel of this set up on our track other than a little push on sweeping corners. Just trying to tweak what I got. I will check out www.rc10b4.com for more info though. Thanks for the info.
Old 06-26-2004, 09:29 PM   #6
as he said try the brown springs in the front the push will go away
craziracer is offline   Reply With Quote
Old 06-26-2004, 11:18 PM   #7
Ybakoff's Avatar
Put 3 washes under the ball studs each side on the front. Also run about 2 deg toe out. I also run 30deg caster blocks and my buggy has great steering. I have brown springs to.
Ybakoff is offline   Reply With Quote
Old 06-26-2004, 11:27 PM   #8
RadioRogue's Avatar
You could try using 32.5 wt oil in the front-move the upper shock out one hole on the rear or maybe a front tire change to a m2 compound.
RadioRogue is offline   Reply With Quote
Old 06-27-2004, 12:27 AM   #9
Tech Legend
Wild Cherry's Avatar
Default ways to increase high speed steer
1. raise ft & rear ride height
2. thicker oil in ft
3. firmer insert in ft tire
4. longer ft camber link
5. a worn down set of ft tires
6. a narrow ft tire has more high speed compared to a wider ft tire
7. stiffer ft spring
8. mount shocks towards the outside holes on towers
try #1 first,
than if not enought go to#5 and #3
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
more steering? racer34v Electric On-Road 3 09-25-2007 11:53 AM
g4 steering rcaddict13 Nitro On-Road 1 08-16-2007 11:13 PM
steering Leyler Micro and Mini Scales 2 07-05-2007 05:30 AM
T-max steering? DriveToLive Monster Trucks 11 07-24-2006 11:56 AM
STEERING problems!! ie no steering creamsodauk Rookie Zone 5 06-30-2006 10:17 PM
