battery charger qustion
the acucel 6 charger can you put to batterys on it and will a car battery work to power it
You can use an auto battery to run the Accucel-6 charger. You can charge two lipo batteries at once wired in parallel, but its going to be awful slow since that charger has only 50watts of charger output power. Depending on what the lipos are (cell count and capacity), it'd prob be faster to cahrge them one at a time.
Safer too, unless you know what you're doing and have the required cabling.
ok so can you charge on 5 anps
is there a converter for going from an outlet to the charger
