Long Island Raceway, NY...Forum >
Old 04-17-2008, 08:07 AM
  #3751
SQC049's Avatar
Trader Rating: 18 (95%+)
Hey Mertz, you mind sharing your B4 setup with me? I'm going to run mine next weekend after the trophy race.
SQC049 is offline
Old 04-17-2008, 09:33 AM
  #3752
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Originally Posted by dmcguire View Post
Hey guys, just wanted to say thanks for the input you all gave me last week about the Lazer SP coversion kit. It should be in early next week and I cant wait to try it out. Hopefully it'll make me want to drive the car more. I have one more question for you all, for the RCE type surface what would you guys suggest for a starting setup on the SP? Thanks again for the help
I run sp box setup with rear shocks on inner hole of tower, 35wt. front and 32.5wt rear, no sway bars, shaft one way (try it without shaft oneway first). I also suggest playing with the ride height often cause i noticed it has a pretty big effect, if the chassis is slapping the car will drive bad and if the nose is too low it will jump funny. I am more a driver then a set-up guru but my lazer is a pretty good car with a couple changes from the box set-up and i love it.
Jason Pelletier is offline
Old 04-17-2008, 09:36 AM
  #3753
Dude, darren's car felt very good.....
Old 04-17-2008, 09:41 AM
  #3754
T. Mertz's Avatar
Yeah no problem Andrew.
Johnny- Me and Darren are running the same setup pretty much, but i made a few changes on my car due to the new layout.
T. Mertz is offline
Old 04-17-2008, 09:53 AM
  #3755
My bad i didnt know.
Old 04-17-2008, 10:15 AM
  #3756
SQC049's Avatar
Thanks Mertz.
SQC049 is offline
Old 04-17-2008, 10:31 AM
  #3757
T. Mertz's Avatar
its all good bro.
who's ready for this weekend.....should be fun.
T. Mertz is offline
Old 04-17-2008, 10:35 AM
  #3758
its all good bro.
I will be when betts get's some tires in. but other then that i am very excited. I have a bit of trouble on new layouts but i think i am up for the challenge.
The triple is dialed !!
....just watch out for the lawn and garden section of lir, lol
Old 04-17-2008, 11:40 AM
  #3759
dmcguire's Avatar
Trader Rating: 32 (100%+)
Thanks again everyone for the setup info. It's very much appreciated.
dmcguire is offline
Old 04-17-2008, 11:45 AM
  #3760
SQC049's Avatar
You have to come down and run that thing at LIR!
SQC049 is offline
Old 04-17-2008, 02:08 PM
  #3761
Goodesta's Avatar
can any1 tell me there setup for a ft b4?
Goodesta is offline
Old 04-17-2008, 02:31 PM
  #3762
T. Mertz's Avatar
Current B4 Setup:
Front:
#1 pistons with 35 weight AE shoick oil brown springs.
Inside hole on tower, outside on arm.
2-b camber link(outside on tower, outside on hub). With 2 ballstud washers.
25 degree caster blocks moved forward(stock).
1 washer under ballstud on spindle.
-1 degree camber.
Ride height- Arms Level.
Rear:
#2 pistons with 25 weight AE shock oil green springs.
Inside hole on tower, inside on arm.
1-b camber link(inside on u-brace, middle on hub). With no washers on u-brace.
Running wheelbase in the middle(1 washer on each side of hub).
0 degree anti-squat.
-1 degree camber.
Ride Height- Bones just above level.
Additional notes:
1 oz. weight in rear. Unscrew front shock bottoms 2 turns. CVD's. Keep O-rings fresh in shocks. LRP Spheree with 10.5 Orion Brushless with 6 cell.
I'll be trying some other setup changes tomorrow, ill let you know if i change anything. Any questions feel free to ask.
T. Mertz is offline
Old 04-17-2008, 02:52 PM
  #3763
Sohlman113's Avatar
Tomorrow is pretty much the start of the weekend. I am pretty pumped. Should be a good time.
Sohlman113 is offline
Old 04-17-2008, 03:24 PM
  #3764
Goodesta's Avatar
mertz where do u pit? i pit by the wall 2nd table in my car is the blue and white b4
Goodesta is offline
Old 04-17-2008, 03:37 PM
  #3765
Still at fuggin werk......
