HELP! ESC Goes Thermal
I have a Hyper 8.5 w/ a Novak HV Pro ESC and 6.5 Brushless motor. The problem is my esc's thermal protection shuts down the esc after about 6 minutes of run time. I use the 11t pinion that came with the Novak conversion kit for this buggy. The motor and batteries generates very little heat..but you could cook an egg on the esc.
Also..the esc will get very hot after about 2 minutes run time without even running it hard. My gear mesh is fine and there is no binding. I have no fan..but I dont' think that will bring the temps down that much. The only other thing I know to do is drop the pinion teeth, which are $10 each! Am I forgetting to check something.
Here's my setup:
Any help would be greatly appreciated!
Here's my setup:
- HV Pro Brushless System 6.5T with 5mm Rotor
- 11 t pinion
- dual 20c 5000mah Lipo packs
Drop down on your pinion. I had the same conversion. I ran with a 9 tooth fine..
Put a fan on your esc, most 1/8 esc needs a fan.
Here's my setup:
Here's my setup:
- 11 t pinion
20C may not be enough for that setup. Sometimes that can generate heat.
Company Representative
Using the fan is absolutely crucial; this is why we provide the fan with the esc!
Because I am not part of Novak's technical support group, I suggest you email [email protected] with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Trouble-shooting TeamNovak's One Touch™ Speed Controls
The more information you provide in your first email, the more quickly tech support can offer you assistance.
Please make your initial email as detailed as possible. Include:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim?
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
~ rotor (old/new)
~ connectors used
~ vehicle & gearing
~ warranty claim?
