Mini-T Questions
Old 06-25-2004, 03:55 AM
  #16
raving-monkey's Avatar
i got a proper servo saver off ebay (i will get you the link in a bit) and it is identical to losi's own (that you get with xxx4 etc) and it works a treat.
i just used servo tape to fix my servo in (as the holes on the lugs are different to the ones on the standard servo
raving-monkey is offline
Old 06-25-2004, 08:11 AM
  #17
Nrctc3's Avatar
I was thinking of getting the Hitec 81MG servo and just modifying the chassis a little bit.
Nrctc3 is offline
Old 06-25-2004, 09:30 AM
  #18
i use the hitec hs55 and it does its job fine..and its cheap
Old 06-26-2004, 09:32 AM
  #19
Nrctc3's Avatar
Default Mini-T Aluminum Chassis
Fullforce RC has released a new full aluminum Mini-T chassis, the review can be found here: RCXotic.com - Fullforce RC Mini-T Aluminum Chassis
Nrctc3 is offline
Old 06-28-2004, 09:36 AM
  #20
macnkitty2002's Avatar
what is your question though?
macnkitty2002 is offline
Old 06-28-2004, 09:46 AM
  #21
Nrctc3's Avatar
I guess my question is... What are you talking about?
Nrctc3 is offline
Old 06-28-2004, 11:03 AM
  #22
i just dont see why anyone would want an aluminum mini-t chassis. the stock plastic chassis is strong enough. plus its not like the thing is going 10 feet into the air from a jump, the car cant get enough air to make it land hard. if it does land from a jump, the plastic chassis should be plenty strong. i guess people just like the look of an aluminum chassis, even though it might not help. just like those companies that make billet reciever boxes for the t-maxx. its not like the receiver case is in any danger, the thing is just adding weight to the truck.
Old 06-28-2004, 11:22 AM
  #23
what is the fastest motor you can put in the mini-t and best battery? Is there any chance of getting up to 30mph with the mini?
mtx3racer is offline
Old 06-28-2004, 11:44 AM
  #24
Nrctc3's Avatar
Good question, I put the Trinity Monster motor and mine and it flys though. Not sure on the speed.
Nrctc3 is offline
Old 07-09-2004, 09:19 AM
  #25
yodace's Avatar
I just order a Mini T from my local hobby shop?
I was wondering about the losi oil shocks i heared they leak. I was wondering what I could do to prevent them from leaking?
Like replacing the stock o rings with aftermarket o rings?
What is another brand of shocks that would fit the Mini T?
yodace is offline
Old 07-09-2004, 01:21 PM
  #26
PSI Racing's Avatar
The Losi shocks work good.
Try these tips from Team Losi.
http://www.teamlosi.com/techtips/Min...k_mounting.htm
If you do get a set that leaks, send them back to Team Losi, and they'll send you the new seals.
PSI Racing is offline
Old 07-09-2004, 03:55 PM
  #27
mattyk6's Avatar
Check out the GPM oil shocks. They are supposed to be really good! Mine are still in the mail. Got them for $23 off eBay from Hong Kong.
mattyk6 is offline
Old 07-13-2004, 12:45 PM
  #28
Trader Rating: 35 (100%+)
Default Battery Building???
How do I go about building battery packs (6 cell) for my Mini-T? I have the tools and materials needed to build the packs, I just can't figure out how the cells are assembled/soldered end-to-end?
Is there another way?
I've assembled many sub-C pack for my TC.
Geppetto is offline
Old 07-13-2004, 05:11 PM
  #29
Nrctc3's Avatar
They use a flexible copper wire. I'm not sure where you can purchase it though. Maybe contact www.TeamHelotes.com since they use it on their packs.
Nrctc3 is offline
Old 07-13-2004, 07:51 PM
  #30
The losi shocks work great. I've found that o-rings from a Traxxas pro .15 carb fit perfectly and seal those shocks tighter than a frog's @$$.
If you want the ultimate speedster, get Castle creations Mamba brushless system and a thunder-power 1900mah 11.1 li-poly battery from Horizon. AT LEAST 28mph. The speed is mind blowing for such a little truck.
Oh yeah, try 30 weight in the shocks, it makes the truck much more stable at high speeds.
gardencityrc is offline
