kyosho dmt ve
Old 09-05-2010, 02:46 PM
Default kyosho dmt ve
i think i found my next rc car:
http://www.kyosho.com/eng/products/r...duct_id=106571
http://www.rceasy.com/2010/09/02/kyosho-dmt-ve-video/
it looks great, is very light and run real well even with stock electronics on 2s lipo!
regards
timaneli is offline
Old 10-27-2010, 10:43 AM
finally receive it yesterday:
the car runs great on stock setup but esc i want to improve steering servo and a new esc!
great car, very light and powerful even on 2s only.
timaneli is offline
Old 10-27-2010, 10:57 AM
Dominick Shaunt's Avatar
totally agree ! I got mine a week ago swapped wheels other than that stock definitely want to go with esc that can handle 4s li-poly ... and custom painted body, and beefy turnbuckles and rod ends pop them off a few times
Dominick Shaunt is offline
Old 10-27-2010, 11:15 AM
Is this truck compatible with the 4wd stadium class with spec tires? like the Hyper TTe
Or it may be compatible with the 4wd SC class? with spec tires again
or is it a completely different thing?
pirape is offline
Old 10-27-2010, 12:56 PM
Definitely would not be in Sc class even with spec tires .. Hyper TTe have no idea what that is or class it runs in ...
Old 10-27-2010, 01:02 PM
carcrazy699's Avatar
Trader Rating: 49 (100%+)
this is a monster truck. i used to have the nitro version of it so it wouldnt be in the same class as the hyper 10tt
carcrazy699 is offline
Old 10-27-2010, 01:06 PM
Lets say we switch the wheels and tired from the SC spec tire why wouldnt it work? too long?
and TTe is a 1/10 class truggy
pirape is offline
Old 10-27-2010, 01:16 PM
angrymelon's Avatar
I have a feeling that even if you put short course wheels/tires on this it's going to be way too wide. The wheelbase might be correct though.
-melon
angrymelon is offline
Old 10-27-2010, 01:20 PM
Only time i've raced a R/C Truck are in true RC Monster Truck racing events like the NRCPTA Worlds competition not sure of class spec's in regards to Stadium or Truggy class spec's Truck is 19" long center to center wheelbase 12.5" arm on truck are pretty long at almost 6" so rims would have to be right offset with the tires and rims i currently use my truck make it 17.5 " wide.. the truck stock is very almost scary light that's why does so well out the box on 2 cell li-poly ...
Old 10-27-2010, 01:27 PM
angrymelon's Avatar
Actually this is almost the same wheelbase and track width as the 10TT.
http://www.kyoshoamerica.com/DBX-VE_p_639.html
All you have to do is slap a truck body on there and bam!
-melon
Old 10-27-2010, 03:53 PM
what turnbuckles did you pop off?
this car with a higher kv motor like a novak hv and a max pro esc on 2s will scream ilke hell.
no need for 3s or 4s lipo and on 2s you can keep the car light!
timaneli is offline
Old 10-27-2010, 07:26 PM
pop at least one of the steering links off at least ounce every time i run truck
but that partialy because like i said i don't run those super light rims it came with i run custom ppp alloy rims .... plan to even change the rims it currently has to a lighter set but bigger "clod sized rims & tires" that put weight back over axles also going to have beefier axles and drive-shafts made....which is one reason to upgrade esc for more power for added weight don't plan to go too crazy but don't like typical stadium truck or truggy look either ...
current tires & rims
Old 10-28-2010, 03:24 AM
with those wheels is normal that happenig.
i want to keep mine light as possible for local racing and bashing!
timaneli is offline
Old 10-28-2010, 09:41 AM
is it me or the truck looks so god damn cheap... It check on Kyosho america and its listed for 679.99$$ WOW
by the way I am interested into buying a 1/8 monster truck that will be a blast to drive
I was looking at the Kyosho Mad force Kruiser VE because its not independant suspention drive and I never drove this kind of truck
is that a good choice I mean am I going to like that?
(I am not a traxxas fan)
pirape is offline
Old 10-28-2010, 10:33 AM
you can already get this car for 500 dollars or less.
the mad force kruiser donīt look a good performance car in my opinion.
timaneli is offline
