Pinion set screws >
Pinion set screws
Pinion set screws
Old 08-30-2010, 03:31 PM
  #16
morgoth's Avatar
Get pinions with 2.0mm set screws instead of 1.5mm.
morgoth is offline
Old 08-30-2010, 03:36 PM
  #17
Where would you find something like that? Remember Slash stuff is 48p
bowl806 is offline
Old 08-30-2010, 03:50 PM
  #18
morgoth's Avatar
Nvm, I use mod1 pinions for my 1/8 scale buggy and the RRP/Tekno pinions had 2mm hexes.
morgoth is offline
Old 08-30-2010, 04:09 PM
  #19
Now that's mean--I'm tellin Mom! The perfect answer for a 50+ year old man to reply with lol!
bowl806 is offline
Old 11-20-2010, 03:57 PM
  #20
Way to remove any stripped allen screw (stripped head).Take a dremel a whatever you have(dremel is better) and grind the head of the screw(outside,surface that is out of the pinion).Grind your allen wrench(a cheap one).Take your soldering iron (80W or more) and solder the wrench in the screw.Unscrew and unsolder(if you want to keep the wrench).
This method ALWAYS works.
AL3xGR is offline
